2.5" vs 4" flip
Discussion in 'The Garage' started by bear76, Dec 6, 2006.
  1. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    Is the only difference between the two the shackle (stock, 4", or 6") or is it the bracket that is different?
  2. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    Im not sure what you meen by the (stock, 4", 6") but the 2.5 inch shackle flip versus the 4 inch flip do have construction differences. the 4" flip puts the pivot hole in the stock position but allows for the flip. the 2.5 inch pivot hole is higher than stock hence the shorter lift. you can get a 4 inch lift with the 2.5" flip kit if you use an extended shackle. I guess that was your question.
  3. bear76
    Oct 16, 2005
    1,065
    here
    Yes. That is kinda what I was asking. The hanger itself is differnt but the shackles are the same length, right.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Yes, same shackle different frame bracket.
