2.56's gear ratio???
Discussion in 'The Garage' started by 81sb, Mar 19, 2004.
  1. 81sb
    81sb Registered Member
    Sep 26, 2002
    14
    Saskatchewan Canada
    2.56\'s gear ratio???
    Well tonight i pulled my diff cover to install my lockright and two things happened 1) I had a broken pinion lock bolt that I have to deal with and 2)I come up with a 2.56 ratio for my R&P. (41/16). I assumed I had an absurdly low ratio in the low 3's but a 2.56? Ive never seen specs for one that low. Anyone heard of a ratio this low before? Its an 81 12 bolt behind a Th350.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Re: 2.56\'s gear ratio???
    Well I haven't heard of those gears. But the guy who did my lockright with me ( Marv thanks!!) put in a new pinion lock bolt (crossshaft, crosspin whatever) for me. It should be replaced anyway, even if it was not broken. It is part of what makes lockright work. The pin will wear out in 5 years with lockright and you replace it. /forums/images/graemlins/k5.gif
    BTW is the 16 really a 15 which makes it 2.73 and sounds right for a th350 truck in smog days /forums/images/graemlins/thinking.gif
  3. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    i think 2.73 is as low as they went. and what the post above says about your 16 being a 15
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    They did make a 2.56 in the truck 12-bolt. A very 80's ratio. I guess they wanted the economy but hadn't invented the TH700 quite yet /forums/images/graemlins/thinking.gif
    Just a warning now... you can only re-gear to a max of 2.73 before you have to change the differential case.
  5. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Wow... 2.56... ouch /forums/images/graemlins/doah.gif Are you sure about the case change? Wouldn't that make 3 different cases running around?
  6. u2slow
    May 9, 2001
    2,217
    BC Canada
    Yep, 3-cases for the truck 12-bolt /forums/images/graemlins/eek.gif
    1) 2.56 to 2.73
    2) 2.76 to 3.40
    3) 3.73 to 4.11
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I see where there are 3 cases also. Dug through the magazines and such here and found the write up which shows 3 case breaks. I will run into that later on as I have 3.08's now. 1 ton future but not until I can kil my 12 bolt. /forums/images/graemlins/thumb.gif
  8. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    And just think, there is probably some mall cruiser, running this ratio, with 44's! ouch!
  9. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Had a car once that had 2.29's in the rear, i thought i miscounted, until i counted 3 more times.
  10. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gifWoah thats really high geared. (numerically lower)
  11. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    A good friend of mine's first truck was a 1981 K-10 with 2.56's in it . We knew it had some sorry gearing in it from the test drive but were just discusted when we pulled the covers and found out that he had the the most unfriendly off-road gears ever offered in a GM 4x4 .
    Not long after that we installed 4.11's and an Eaton Posi in the rear just to make it bareable off-road with 35's .
  12. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    my 81 k10 came with 2,56s too . i thought my 305 was a complete dog but it was mostly the gears . /forums/images/graemlins/hack.gif
  13. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yep gear ratio from 2.56 to 3.08 is the cause of bad performance/acceleration, alot of ppl dont understand this at all
    the last 2.56 truck i came across was a 77-80 big 10 2wd pickup, it had 2.56 listed on RPO label, i still have the label somewhere around here, have had it for years, i snagged it back when i first started hunting for and saving RPO stickers from trucks
    my stepdad he has 2.73 axles under his 82 k10
    i been trying to tell him for years that he needs to find 3.42 or 3.73 axles for it, weve got this 86 k5 out here with good 3.42 front axle and he could get it real cheap but no matter how much i try to explain it to him he doesnt understand it all how it will help the ttruck perform and pul things for him,
    if i were him id be snagging the axle and hunt up a good 8.5" 3.42 rear for the k10 but he doesnt get it,..
    so il just let him keep on hauling gravel and boats with the truck until he blows up something again, he already burnt up the tranny once so far and had to have it rebuilt, i cant wait til he busts and axle or the 208 case or a driveline, but i guess thats what he gets for not being able to read or write at age 43, however he is very mechanically inclined and has photographic memory,.
    tradeoffs..
    just ;ike the tradeoffs of losing gas mileage in favor of better performance with lower axle(lower numerically) ratios
