2.5L to Sm465
Discussion in 'OffRoad Design' started by Islander, Apr 10, 2003.
  1. Islander
    Islander Newbie
    Apr 10, 2003
    3
    Will they bolt up without any flywheel or clutch issues?
    If so what stuff should i get to make them work together?
    thanks!
    Cody
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    If your are talking a chevy 4 cylinder....it doesn't bolt to the 90 deg pattern of the chevy V8 (and 4.3 V6). It is the same as a chevy 2.8 (or 3.4) V6 - 60 degree pattern. Advance adapters might have something.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    That's the info I would give you. I'm not much more help on this one.
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The newer 2.5's have the small b/h pattern, but the older ones (i.e. from Chevy flat-nose van, Chevy II) had a "normal" v8 pattern.
    I would assume internal balance - only because everything except the 400 and 454 were. Any v8 or 194/230/250 inline-6 flywheel should work.
