2.73 10 botl axle rant !
Discussion in 'The Lounge' started by R72K5, Sep 9, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    the 78 gmc c1500 out here has a 10 bolt 8.5" and i had the stamping code RUB looked up and the dealer says its frickin 2.73 ratio,.........
    ahhhhhhhhhhh! !!!!!! why in the hell did GM build and install so damn many 2.73 10 bolt 8.5" axles, i keep finding them left anf right now, under the lightest 1/2tons, the ones with only four 52" rear leaf springs, never find this junk undert he big 10s and anything with the 56" 8 leaves in rear.. they always have at least 3.07 if not 3.40- 12 bolts, even a 3.07 would be better than this 2.73 garbage, i do have a 3.07 eaton posi 12 botl out here i might just put under, but its not a huge difference in ratio though, so i dunno...
    man.....
    grrrrrrr........ piece of crap junk 2.73 ratio......
    boy they sure got in a hurry to start using the 10 bolt axles on the rear, even alot of 77's have the 10 bolts under them even, wish i would have saved some of the perfectly good 67-69 c-10 12 bolt 3.73 axles i simply disassembled and junked a could years back..
    sigh....
  2. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    My 81 Jimmy came with a 12 bolt stock...
    and 2.73's /forums/images/graemlins/rolleyes.gif
    Rene
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    That is not as bad as the 2.56 ratio 10b/12b my friend found came in his '81 K10 /forums/images/graemlins/eek.gif
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    My 81 Jimmy came with a 12 bolt stock and 2.73's /forums/images/graemlins/rolleyes.gif
    Rene
    12 bolt was through 82, what size leafpacks and how many leaves per pack originally on the truck ?
    on a side note:
    interesting.. you sure its not 2.73 ratio instead? ive only seen 2.73 in 10 bolts and 2.76 in 12 bolts, and ive been through alot of trucks and axles, hmm..
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i remember once finding 2.56 ratio in a 77 or 79 c-10 bonanza pickup, it had power doors and ratio listed on SPID label, i remember it being an oddball ratio, 2.56 was normally only in cars and mainly in the 7.5" axle
  6. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I guess that I was a lucky bastard, I bought my 78 when I knew nothing of these trucks. It had come from the factory with a 6 cyl that was later swapped to a 350, so I ended up with a small block and factory 4.10s. Too bad I roached the gears in both of them by running 38s. /forums/images/graemlins/rolleyes.gif </font>
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah, only bad thing about series 4 gear ratios is that the pinion gear diameter is alot smaller than series 3 ratios
    ill find out for sure if 4.10 was factory available in 10 series trucks as soon as the GM specs sheets i ordered get here, i ordered for 76 and 78 years chevy trucks, as far as i have ever seen or heard 3.73 was deepest 10 series ratio ever offered, and in 63-72 years 3.73 was std.equipment.
    we'll see ! /forums/images/graemlins/laugh.gif
  8. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> The gears that were in the truck were GM gears and the speedo was correct, so if they were changed someone did a complete job on it. The truck was bone stock other than the engine change, it appears that it spent most of it's life working hard somewhere in Washington state. I am 99.9% sure that 4.10s were pretty common in the 6 cyl trucks. </font>
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I don't know what the magic incantation was that you had to recite to get 4.10's back then, but they were available in K10's. I had a '77 K5 that came with 3.08's. Needless to say, they really sucked with 36 inch tires. /forums/images/graemlins/eek.gif But a guy I worked with had a '76 or '77 K10 pickup with factory 4.10's. He hated the 4.10's because he ran stock size tires and this was long before overdrive trannies were common. /forums/images/graemlins/shocked.gif So we jacked our trucks up side by side one weekend and swapped axles between our trucks. He was happy with the 3.08's and I was happy with the 4.10's. /forums/images/graemlins/thumb.gif
  10. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Our 67 C10 came with a 327 and standard and has 4.10 gears in the 12 bolt rear from the factory...
  11. landsmasher
    landsmasher 1/2 ton status
    Mar 13, 2002
    4,423
    California, The Blow Me State
    My 78 K5 came with a 12 bolt with 3:08 gear ratio. It's a fed truck. Don't know if that means anything.
