2.75" or 4.25" Backspacing
Discussion in 'The Garage' started by clubba68, Jul 29, 2004.
  1. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    2.75\" or 4.25\" Backspacing
    I need to order wheels like NOW so I need a fast response. These are for a 1970 K5 with 3/4 ton axles from a 1974 pickup. The front calipers have already been ground a little bit. I would like to keep the wheels as "deep" as possible (ie. as little backspacing as possible), but I have also heard that little backspacing [ QUOTE ]
    If you go to 2.5" BS you will most likely be into a "reverse center" wheel which would be almost imposible to mount the tire from the outside. Wheels normally have a recess for the bead to sit in on the outside while you are putting the tire on the rim. When you go past a specific ammount of BS (different for all rims but 2.5" is most often reversed) they have to turn the wheel around on the center so the recess is on the inside. Everything works fine and dandy till you put a beadlock on them because the tire shop will just put the tires on from the back of the rim. -Triaged
    [/ QUOTE ]What do you guys think? /forums/images/graemlins/1zhelp.gif
    2.75" and 4.25" are my two choices. /forums/images/graemlins/waytogo.gif
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Re: 2.75\" or 4.25\" Backspacing
    check the other post. /forums/images/graemlins/whistling.gif
  3. clubba68
    Dec 6, 2002
    1,511
    Thanks Jeremy.
    Anybody else have any input?
  4. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Call the company that you are ordering rims from and ask them if 2.75" BS is a reverse center. Beyond that I would say the less B.S. you have, you wear bearings out faster. Or 2.5" is worse for wheel bearings than 4.25". I'm running 4.25" and have no troubles there.
    Why do you want deeper rims?
  5. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    whats our timeline here?
    when I was doing the rear wheels for my 40 chevy. I was looking at 15 x 12 or 15 x 14 ( I have since redone the tubs and will go for a 20x10)
    and I was speaking with my buddies uncle who has been into cars for 30+ years, he drag races, has done the 4x4 scene and when I asked if I needed to narrow the rear end for the width he said it wouldn't effect it enough to worry about it.
    I think with general maintainance it will not be that bad to go with a 2.75 vs the 4.50. You also have to account for tire size and vehicle weight and how the vehicle is treated. (jumping the dunes on 38's will do more damage to them then a 44tsl that just runs the street.)
    Theres 2 cents from my pocket.
  6. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    4.25 is really a better wheel, less "swing" to the outside when you turn, easier on wheel bearings, less rubbing on the cab and fenders when you turn, the tires will be under the fenders instead of sticking out, you'll fit down trails easier...
    On the plus side for the 2.75" BS... Ummm, they look, like totally dope, dude. Deep dish rims are the shizzle. /forums/images/graemlins/screwy.gif
    Go with 4.25 for function, 2.75 if looks are more important.
  7. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I run 2.75" bs 15x8's and they are reverse. Just about any bs less than 3.5" will be reverse. The neat part is you don't need bead locks as much with a reverse wheel. The drop center is 6" from the outside of the wheel (a standard wheel has the drop center 1" away from the out side). The bead has to slide over 6" now just to blow. As the bead moves over the inside area is getting slightly smaller (pressure is going up) and making it even harder to get the tire to the drop center. I never noticed any extra wear on the bearings, but they sure killed ball joints.
  8. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    whats are timeline here?
    when I was doing the rear wheels for my 40 chevy. I was looking at 15 x 12 or 15 x 14 ( I have since redone the tubes and will go for a 20x10)
    I'll agree with you here and good points. Perfect world probably not much different in the timeline. I for one will never say that I maintain everything exactly as it should be. For my little corner of the world life just isn't that convenient. /forums/images/graemlins/waytogo.gif
  9. clubba68
    Dec 6, 2002
    1,511
    OK, after hearing a couple concerns on other another forum and on the phone of the wheels hitting the TRE's, I decided to go with the 2.75's. That way I won't have to grind the calipers anymore and also won't have to worry about the TRE's at all. Thank you all for your input. /forums/images/graemlins/waytogo.gif
  10. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i have 2.75' backspacing on 15x10s, they are the reversed center. ive test fitted them on my stock k20 and the rear sticks out from the fender 2" and the front 3.5". a problem if you have to run on the road and law requires the tires to be covered.
  11. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    hmm, no problems on mine, but they are 15x8's w/ 4.25 BS and 35x12.50x15 SSR's. They have worked out really well for me.
  12. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    4.25" BS will not hit the TREs.
  13. clubba68
    Dec 6, 2002
    1,511
    Too late now. /forums/images/graemlins/whistling.gif
  14. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    the two rigs I know that run em did. One actually cut through his side wall and almost rolled his blazer. 40" truxx's.
  15. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I guess the problem with this post is that he never stated what size tires he runs and how wide the rims were gonna be /forums/images/graemlins/dunno.gif
  16. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    15 x 10 with a 35x15.5x15 swamper
  17. clubba68
    Dec 6, 2002
    1,511
    Spaced that part. What he said. /forums/images/graemlins/thumb.gif
  18. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I hope you like to replace ball joint, and I hope your ball joints are under warranty. 2 guys here in AZ run that combo 2.75" BS and if do some good wheeling they replace there ball joints every 3 months. TheRobZilla gets about 5 runs on a set of ball joints before they are trash.
    Harley
