2" Add-a-Leaf
Discussion in 'OffRoad Design' started by dawson444, Feb 6, 2001.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    2\" Add-a-Leaf
    How well do you think a 2" Add-a-Leaf would work? Would it still have the 0 spring rating? Thanks!
    Dawson
    88 K5
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Re: 2\" Add-a-Leaf
    The added spring rate is dependent on the length of the leaves, so if you keep it the same length as a block, you'll keep the same rate. However, you're going to have the same drawbacks as a 2" block as far as leverage and axlewrap, and I strongly advise against it in the front since you would add a lot of side to side lever arm in a very important place.
    Making the world better, one truck at a time.
    SW-ORD
