2" add-a-leaf's (zero-rate) - $60.00 + ride
Discussion in 'Pacific Region' started by Topdown, Jan 25, 2005.
  1. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    Vancouver, Washington, U.S.A
    I have a set of 2" zero-rate add-a-leaf's for sale also...
    These have been tested and have proven tough enough for even the hardest wheeling in a K5 (this set is brand new, the prototypes were tested) with no issues at all.
    two, 2" add-a-leaf's (zero-rate) and the hardware to mount them to your packs for $60.00 They are made from solid steel, guaranteed not to crack, break, warp or crush.
    If you dont believe me, ask Shane74, he has caught enough air with a pair of these in his blazer he should be getting frequent flier miles.
    I posted this in this forum because they are solid steel (heavy) and you can DEFINITELY feel the difference between these things and sh*tty lift blocks (aluminum or cast)... these things kick ass.
    They are drilled for 1" and 1.5" offset so you can relocate if you want to.
