2" body lift for diesel???
Discussion in '1982-Present GM Diesel' started by 84CUCV, Dec 1, 2002.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    2\" body lift for diesel???
    I can get a new 2" kit for 50 bucks. It is for his 350 k5. It does not say anything about a diesel. Will it work?? Thanks Mike
  2. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    Re: 2\" body lift for diesel???
    Check the archives.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I think your biggest problem is making the fan shroud work.
    /forums/images/graemlins/burb.gif
  4. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Did a search for 2" body lift for a 6.2 and nothing was found. So does anyone know if this can be done? Thanks Mike
  5. calcide
    Dec 21, 2001
    283
    Try your search again
    *HINT* search for "body lift" in this forum *HINT*
    Excessive meanness removed.
  6. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
  7. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Why do you feel the need to be such an A$$hole? I don't have a problem with telling someone to do a search or even giving them pointers on how to effectively do a search, but the smart a$$ comments aren't necessary! /forums/images/graemlins/angryfire.gif
    This board didn't become great by people acting this way toward one another, so knock it off! /forums/images/graemlins/angryfire.gif
    Mike
  8. 6.2L Jimmy
    6.2L Jimmy 1/2 ton status
    Jan 2, 2002
    164
    Montreal,Quebec
    I agree!
  9. u2slow
    May 9, 2001
    2,217
    BC Canada
    I put a 2" body lift on my crewcab, and the shroud had to be removed for fan clearance. Now the POS overheats on any uphill grade under 40km/h (25mph?). Apparently, you're supposed to run the fan as close as possible to the rad when not using a shroud - not something I've entirely comfortable with on a 4x4 that gets some twisty action.
    The whole truck is up for re-design when it gets dieseled /forums/images/graemlins/thumb.gif
  10. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    thanks for the help guys. Calcide, /forums/images/graemlins/rolleyes.gif why do you bother! You are NO help. Mike
  11. 86 4door
    86 4door Registered Member
    Nov 28, 2002
    15
    pottstown PA
    i put on a 3" body lift on my 86 K30 6.2 as far as the radiator shroud, i cut the bottom of mine off, so you still have about 3quarters of it left.no over heating problems yet- but it has not been above 60 degrees since install. i live in pottstown PA. about 40 minutes west of philly. if you would need a hand, i might be able to help you out
  12. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    864door, I might take you up on that. For now it is on hold. I just got laid off. Well, Thanks a lot. mike
  13. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Sorry to hear that, do you have anything lined up?
    Well try and look on the bright side, now you have more time to work on your truck, do things that don't cost money or not much at least.
    I have a ton of things I can do, and if I loose my job I know what I will be doing.
    Chin up. /forums/images/graemlins/smile.gif
  14. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    No, I don't. My mother is sick. I called out to take care of her. Then the a$$hole gave me the boot. Trying to keep the chin up. It is not looking good for me right now and to top it off the town is on my a$$ about all the chevy parts all over the place. Thanks for the replys. Imiceman44, yea, you are right I have the time to finish the k5 now. Well, Take care Mike
