2" body lift is here!!!
Discussion in '1936-Present Suburban' started by muddysub, Sep 12, 2002.
  1. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    2\" body lift is here!!!
    it arrived today! /forums/images/icons/grin.gif my 2" body lift is here. i've done a 3" on mudbogAD's jimmy before but never on a suburban. is it any different? i noticed 2 mounts on the sub have no bolts through them but all the pucks have bolts in them. and it's a 2" kit but the shifter extension is 3" long is that a problem?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: 2\" body lift is here!!!
    Those 2 areas that have no bolts, I've seen where people have left them out and drilled holes and put them in, I personally put them in. As for the shifter length, you may not even have to extend it...I had a 1/2" of extra length on my stock shifter, but I went ahead and made a new one anyways. One little mod that isn't mentioned with the kit that I did on mine, is after you lift the body (including rad) you will have a gap under the lower rad shelf, I took and installed stock axle bumpstops (the 3" tall ones) one on each side to help eliminate the gap and provide cushioning if it gets jarred on the trail. Hope this helps yeah.
  3. muddysub
    Jun 23, 2001
    10,452
    489
    between the rad and the front clip?
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    yes, i drilled a hole in the top of each frame rail and bolted in.
  5. muddysub
    Jun 23, 2001
    10,452
    489
    oh, hmmm... i'll look at doing that.
  6. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I took pics of mine yesterday. I'll get them uploaded today.
