2" body lift Steering Shaft Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by radar, Mar 18, 2002.
  1. radar
    radar Registered Member
    Oct 28, 2001
    26
    2\" body lift Steering Shaft Question
    I have an 86 K5 Blazer I just got my 2" body lift today
    but before I install it does anyone no if I have to do any mods
    with the steering shaft If so could you give me some tips
    Thanks for the info guys!!!!!!!!!
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    Re: 2\" body lift Steering Shaft Question
    i installed a 3" on my buddies (mudbogAD) jimmy on sat and all you have to do is unbolt the shaft at the firewall and dash so it can move freely and lift away! it has a slip joint in it that takes care of it. with a 3" body lift mudbogAD's steering is fine. so no worries man.
  3. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    Yes, exactly what muddysub said. It works fine without any mods.
  4. Re: 2\" body lift Steering Shaft Question
    One problem I am sure you are going to run into, because I did is with the transmission linkage. I installed ORD's 1" Body lift and my shifting was all off. It turned out to be the transmission likage was "stretched". So I am just saying this because I ran into the problem with my 1" so I know you probably will. Let us know how it turns out. Good Luck
