2" body lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by walt88, Nov 2, 2000.
  1. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    2\" body lift
    I ordered a 2" body lift kit. i know a 2" requires both linkages to be extended. I am having a garage do the lift, what should i tell them to do that they wouldn't know about?
    Keep the shiny side up, and the greasy side down.
  2. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    Re: 2\" body lift
    <font color=purple>What are they charging you to put it in ? I'm thinking of having a shop put mine in too soon.</font color=purple>
    <font color=purple>L8r,
    .Riz.<font color=purple>
  3. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Re: 2\" body lift
    Does the shop know anything about installing body lifts? How many have they done? Who made your kit? Your fan shroud may/most likely have to be trimmed. And your radiator hoses may need to be lengthend. Along with you gas filler lines. Check your steering too, we used a spacer on my buddies till he could get a lengthend shaft. He has a 3" kit though. Some/most of this stuff should have come in the kit. Check your battery cables to see if they need to be extended too. Your bumpers will have to be raised, mostly a "looks" issue. There is a bundle of wires that goes up the drivers side that MUST be allowed to stretch. If you abrate these you will lose your fuel pump and other little gremlins will appear.
  4. walt88
    May 24, 2000
    430
    Monmouth County, NJ
    Re: 2\" body lift
    I don't think the shop has done many. i ordered the kit from 4x4 Wholesalers. Now I am a little hesitant about doing this. I hope all that stuff comes in the kit. They said it is the most complete kit you could get.
  5. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    Re: 2\" body lift
    They are super easy to put in. I suggest if you have the time, a few buddys and a few hand tools you could do it yourself. I put mine on my 86 Chevy Truck. It only took me an afternoon to put it in. You may have to take it too someone who has a welder to put in the tranny linkage extension in. Other than that its super easy to put in.
    Dazed and Confused in a 74 Blazer
    Zeppelin
  6. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    Re: 2\" body lift
    <font color=purple>Well, I've changed my mind about having a shop do mine, I though if the price wasn't too bad, I'd have somebody do it since I don't have much free time as of late. I've done them before and they aren't that hard unless the bolts are real rusty. I called a shop near me and they said they would charge around $1000.00 bucks to put one in !! ARE THEY INSANE !! $1000.00 !!! I basically said they were crazy to charge that much but the guy I was talking to said that's what everybody would charge. If they knew what they were doing, it wouldn't be hard at all for them to do one, I just couldn't beleive they would charge that much ! Do it yourself !!
  7. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Re: 2\" body lift
    I agree doit yourself! Also you may want to consider replacing the body bushings also! Energy make a kit for all the body mounts! Oh and hopefully you will get new carage bolts with your lift kit.If not replace them too by running down to your local HWere store.
    Good luck
    http://www.burt4x4.coloradok5.com
  8. KING K5
    KING K5 1/2 ton status
    Sep 28, 2000
    172
    Sacramento, Ca.
    Re: 2\" body lift
    I know some of you don't like 4WPH but they charge $300 to install a 3" body lift, just my 2 cents!
  9. 1HIHUM
    1HIHUM 1/2 ton status
    Jun 28, 2000
    366
    Fremont, CA
    Re: 2\" body lift
    They are not hard at all. I put mine in over a weekend( doin' other stuff at the same time) I made a new tranny shift rod from metal bought at the harware store. And I didn't see anyone mention the speedo and ebrake cables...watch them for length as well. Good luck.
  10. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Re: 2\" body lift
    Like everyone said, do it yourself. So easy.
    Riz, $1000 for a Body lift??? RIP OFF is all I have to say about that. Man, if yall lived near me, I would charge like $200 to do it. That's me though. There is a shop around me that charges about $300 do it.
    Boss
    http://www.boss.coloradok5.com
  11. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    Re: 2\" body lift
    <font color=purple>Boss, I S#!T you not....$1000 clams ! They are out of theirs minds ! The only reason I was looking into is was that time lately for me is rare......6 mo. old girl that's teething. I'll still squeeze the time in soon and do it myself. I've done them before and they aren't that bad, just time consuming.</font color=purple>
