2 bolt or 4 bolt main in 73?
Discussion in 'The Garage' started by trailblazr81, Feb 24, 2007.
  1. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Would a 73 K20 with 350 have 2 bolt or 4 bolt mains? My current stroker has a 2 bolt block bored .060 over, so Im looking for another block to use for my next rebuild.
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    There is no rhyme or reason for a 2 or 4 bolt block. Some got 2 bolt and some got 4 bolt. Also there is no definitive way of telling 2 or 4 bolt except to pull the pan.
  3. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,030
    1,347
    Kzoo, Mi
    anyones guess. If it has a 8" balancer it MIGHT have 4 bolt....other than that...drop the pan to be sure.
  4. dyeager535
    26,977
    Don't get much info from folks on this, but what I've been able to gather so far is here:
    http://dyeager535.topcities.com/suffix.html
    Way too many engine codes out there for me to even get close to having them all, but so far still have not been proven wrong that suffix codes (when present) WILL indicate 2 or 4 bolt.
  5. 76zimmer
    Nov 14, 2005
    23,030
    1,347
    Kzoo, Mi
    according to the list you have a 010-020 on there, is that the one under the timing cover. I heard those were higher nickel? content in the casting or something to that effect.
    Thanks for posting those no.s
  6. dyeager535
    26,977
    Getting off topic, but heres a thread discussing the 010/020 blocks. I asked for proof, sort of got it, but I'm still a bit skeptical. I've seen GM literature that is incorrect before, I would be completely sold if I saw plans for the blocks or ingredient listings from the foundry I guess. :)
    http://coloradok5.com/forums/showthread.php?t=190270&highlight=010+020
