2 bolt or 4 bolt main
Discussion in 'The Garage' started by wraenking, Jun 29, 2004.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    just found out by looking up the casting number on the engine i got that it is a 2 bolt main. can i still use this?
    the casting number is 3970010 and it says it could be 2 or 4 bolt, and 327 or a 350. ahhhhhhhhh
    thanks
    tom
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Re: 2 bolt main
    Can you use it? Can you explain a little more? Do you have a 4 bolt main now and want touse the new 2 bolt main..using just the block or what??
  3. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    Re: 2 bolt main
    im confused because i looked at another site and that casting id could be 2 or 4 bolt. so i dont know what the hell i have.
  4. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Re: 2 bolt main
    only way to tell for sure is to drop the pan
  5. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    Re: 2 bolt main
    ok, and what do i look for, and am i screwed if it is a 2 bolt
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: 2 bolt main
    No, you're not screwed if it's 2 bolt. There really is no reason to have a 4 bolt main engine in a K5 unless you're mud racing or something.
    305s were installed in MANY trucks for a long time. ALL of them are 2 bolt mains and they work just fine.
    4 bolt mains are only necessary for heavy duty trucks (3/4, 1 tons, etc) and for high RPM blasts. And even then, splayed mains are preferred to factory 4 bolt mains for the most extreme of engines.
    For the 400 SBC, the desireable block is the 2 bolt main one, too.
    I wouldn't fret at all about having a 2 bolt main engine (if I had one). There's absolutely nothing wrong with a 2 bolt main.
  7. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    Re: 2 bolt main
    but is it a 350? my buddy said it was. said it was bored over .30 and everything. i just ripped out my 205, and i really wanted this "350"
    lol
  8. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Re: 2 bolt main
    the casting # you gave is for sure a 350. I've owned a few with that same #
  9. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    Re: 2 bolt main
    ok, but i looked it up and it also listed as 327?
    sorry to be a pain, im just freaking out here. lol
  10. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Re: 2 bolt main
    Is it in yer rig?
    On a stand?
    What is it you are lookin to build?
    There is nothing wrong with a mild SBC with 2 bolt mains.
    Start strokin it then ya can start lookin for one with 4 bolt mains..
    Most likely it is a 350, I just went through this with my hoopty.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: 2 bolt main
    327 and 350 are the same block. It is the crankshaft and pistons that make one different from the other.
    Without running the numbers on the crankshaft it'd be impossible to know which one you've actually got. I'd say you probably have a 350.
  12. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    Re: 2 bolt main
    ok, thanks guys. the fact that the my friend said its a 350 bored .30 over, i ll go with it, its just when i looked it up, i panicked. i want to get it in the blazer by the weekend, so wish me luck!!
  13. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    Re: 2 bolt main
    Good Luck.... /forums/images/graemlins/waytogo.gif
  14. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Re: 2 bolt main
    Just buy some new ARP studs and call it good. No worries, you aren't running a supercharged alcohol dragster, are you?
  15. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    Re: 2 bolt main
    Using a 2 bolt block shouldn't be a problem. My mildly built 406 is a 2 bolt main and I haven't had any problems.
    Also you can always get the Milodin splayed caps and make it stronger than a stock 4 bolt main....
  16. dyeager535
    26,979
    Re: 2 bolt main
    Whats the suffix code?
    Passenger side, just forward of the cylinder head, looking down on engine as it would be installed in the truck, on the flat pad, stamped in.
    If it turns out to be a truck block, (suffix code will tell) you can pretty much be guaranteed it's a 4 bolt, although I'm sure there are a few that weren't.
  17. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Re: 2 bolt main
    yeah I look for 2 bolts now cause you can just go to milodon splayed and be better off.
  18. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have seen my share of that casting number, all but one had 4 bolt mains. I had the casting number book, loaned it and never got it back. I remember it being 72-76 truck AND cars with optional engine ( like ss's and s3's or A/C or towing equipped ) /forums/images/graemlins/k5.gif
  19. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Mines a 2 bolt. I thought pre '77 blocks had nickel in them which made them stronger anyway.
    Think about, how often do you see a block cracked in half? /forums/images/graemlins/dunno.gif
  20. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    If im not mistaken, 4-bolt mains didnt appear until the 70's. There were alot of very fast cars in the 60's that ran 2-bolt mains. If you dont plan on running it over 6500-7000 RPM's as a wild motor, the 2-bolt will work fine. If you are going to spin it high RPM's, I would spend the extra money and have it balanced. Ive seen a few blown motors but never seen one drop the cap due to a main or rod bolt failure unless it extremely high performance. Mostly broken rods, broken crank, spun bearings, etc.
