2 bolt or 4 bolt?
Discussion in 'The Garage' started by BigCountryx, Feb 28, 2006.
  1. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    How can I find out if my 1990 Blazer came with a 2 bolt or 4 bolt main?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Look up the casting numbers on the Mortec website. SOmetimes they will say 2 or 4 bolt though.
    Or you could just drop the oil pan
  3. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    '90 truck is basically guaranteed to be 2 bolt.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, you can bet it's a 2-bolt.
  5. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Unless its been replaced, then its a Q of, with what.
  6. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    Thanks, how inferior is the 2 bolt when compared to the 4 bolt. Are you just more restricted to how much power you should try to develop out of it due to the strength or what? If so, what's the ceiling, power wise, to build a 2 bolt?
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    2 bolts can be built to handle up to 400 hp no problem. But over 350 HP the main caps tend to walk around. This can be cured with studs or splayed mains, billet caps ect.
    4 bolts are better for high performance and high load apps. GM went to the 4 bolts in truck cuz truck engines under high load are very prone to detnotation. That puts a lot of strain on the mains so 4 bolts were needed.
    Stock 4 bolts are only rated up to around 350 HP. GM makes caps that are rated for 450 too. So if you use a 4 bolt in high HP apps you should do some work on the mains also.
    for high performance race or a truck engine under heavy loads use a four bolt
    For basic street/strip and light duty truck & 4X4. A 2 bolt will be fine.
  8. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    if you keep the rpms under 5500 you should be fine
  9. drop the hammer
    drop the hammer 1/2 ton status
    Feb 26, 2006
    160
    Massachusets
    How bought for an 87. Mine is a fully loaded with the 350 option. I was informed, maybe wrongly that its a 4 bolt. Not that it would bother me that much cuase I dont plan to go to crazy with the engine, but does anyone know what engines in what years where 2 bolt or 4 bolt. Would be much appreiated
  10. Indyblazer
    Indyblazer Registered Member
    Apr 24, 2005
    35
    Indiana
    Chevy 2 or 4 Bolts ??
    When you get into to building Chevy small blocks for serious HP there are many considerations about engine blocks.
    Generally the Chevy smallblock motor DOES NOT have a weak bottom end. Something else usually breaks before the crank assembly, even on a 2 bolt main.
    I had a friend that run an 1/8 mile with Supercharged Alcohol/Nitrous small block chevy motor. He used 2 bolt main blocks. He broke lots of pistons and bent a lot of valves and rods and blasted a few rods through the sides of the blocks, but NEVER broke a crank assembly.
    On the pre-1987, the 2 bolt main motor block was thicker at the webbing under the crank, than the 4 bolt main. So some engine builders sought those blocks and had them machined for after market "splayed" caps.
    ALso, on the pre-1987 blocks there were "4 bolt casting numbers". This casting MAY OR MAY NOT be a 4 bolt main. The casting number tells you only that this was the casting that they used for the 4 bolt main --- Not that it actually was machined for the 4 bolt caps.
    The best method for determining 2 or 4 bolt main caps is to drop the pan and LOOK :eek1: .
  11. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Pull the pan, absolutely. Look at this list, it's clear as mud which blocks had 4-bolt main caps (with a few exceptions):
    http://www.nastyz28.com/sbchevy/sblock.html
