2 bolt or 4 bolt
Discussion in 'The Garage' started by K5Dan, Oct 8, 2003.
  1. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    can someone explain to me how I can tell the difference between a 2 bolt or a 4 bolt?also which in your opinion is stronger ? thanks in advance /forums/images/graemlins/thumb.gif
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Without pulling the pan, on a smallblock 350, most 3970010 casting number block's are 4 bolt main's. 4 bolt's really are'nt that great at being stonger than a 2 bolt block. Because of the outside bolt's bore's are in the webbing of the main bearing saddle's. /forums/images/graemlins/grin.gif
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Do you mean, "tell the difference by looking at the engine externally?" As far as I know...there's no way to do that. You need to pull the oil pan. Then, once that's off, look at the main bearing caps. If there are 4 bolts holding each one into the block, it's a 4-bolt-main block and if there are 2 bolts, then it's a 2-bolt-main block.
    As for which is stronger. If I were to buy a block, I'd get the 4 bolt just because I like the added security of over-building everything. BUT, there is nothing wrong with a 2 bolt engine so long as it doesn't see RPMs much over 5 grand.
  4. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    A splayed-main 4 bolt is stronger than a regular 4 bolt which is stronger than a 2 bolt.
    The difference is in the center three main caps.
    The easiest way is to look at the casting number which is behind the driver's side cylinder head on top of where the bellhousing bolts to.
    I've noticed recently that the 4 bolt main blocks usually have a threaded hole at the top of the bellhousing. I don't know if this is a theme or just a freak coincidence.
  5. K5Dan
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    hey thanks guys !this all started when me and a nieghbor where tearing down the engine out of my 73 k10 casting number 397010. I said it's a four bolt because the main caps .he said no it was a 2 bolt because the ones on the ends have two bolts.so i pulled him inside and made this post (hoping i was right).after his supposedly meachanic step dad also said it was a two bolt. /forums/images/graemlins/thumb.gifthanks again! where else can you go at 8ish at night to ask ?'s like these and get the right answers /forums/images/graemlins/thumb.gif
  6. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    379010 blocks=4 bolt main blocks...have one in the garage waiting to become a 385 stroker one of these days...
    4 bolt is stronger than 2 bolt
    if you splay a 2 bolt block and make it 4 bolt, it is now stronger than standard 4 bolt...make a 4 bolt a splayed 6 bolt...and you wont break lol
  7. dyeager535
    26,982
    191
    Not all of them nastyz28 casting #'s
    (BTW, I believe you mean 3970010)
    *TRUCK* 350's are almost universally 4 bolts (which is why suffix codes are about the best engine codes to use), I have yet to find one that isn't, but I'm sure they exist.
  8. Confedneck
    Nov 1, 2002
    5,236
    yes i do mean 3790010.. and i meant truck blocks as this is primarily a truck/k5 site...
    /forums/images/graemlins/grin.gif but thanks for clearing it up... /forums/images/graemlins/thumb.gif
  9. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    But arent pre-'77 i think, 2 bolts strong enough because they have nickle in the block?
  10. dyeager535
    26,982
    191
    That nickel thing has never been proven. You've heard it was a year thing, others say its related to the "010" and "020" cast into some of the blocks.
    No literature or tests have yet surfaced to prove any theories as to block strength. Oldsmobile motors have the same myths surrounding them based on year/nickel/tin content, with the same *proof*. None.
