2 coolant temp sensors?
Discussion in 'The Garage' started by beastofablaze, Aug 12, 2006.
  1. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    Do some k5's use 2 coolant temp sensors?
    I have a leftover sensor after my swap and it won't fit in any of the water plug holes in the intake manifold.... it'll only fit in the head. My coolant temp sensor (# 1 I guess?) on the other hand fits right into a hole in the manifold...
    Crankshaft sensor is hooked up as well as the knock sensor... I'm stumped.
  2. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    i know coolant temp sensors will fit in the top of the water pump. there is most likely a plug there now. ive never personally seen a sensor there from the factory though.
    edit: i think i misunderstood your post. i think more details of the truck are necessary
  3. dyeager535
    26,979
    More than likely you've got a gauge temp sender and an ECM temp sender. (either a CCC or TBI truck, since the poster is in CA) The one wire sender is for the gauge, two wire is for the ECM.
    ECM one is in the intake, gauge is in the head.
  4. Kiqman
    Kiqman 1/2 ton status
    Dec 14, 2004
    102
    Portland Oregon
    What He Said
    The one in the head goes to the dash gauge. The one in the manifold goes to the ecm.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Crankshaft sensor? TBI doesn't have a crank position sensor. It uses the hall effect in the distributor to figure that out.
    There should be 2 ECTs, one for the ECM one for the Gauge. one is in the intake manifold and one is in the cylinder head. Couldn't tell you which one is which off hand, its been a long time since I've messed with TBI.
  6. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    I can confirm that on my 87 TBI the sensor in the manifold is for the ECM and the sensor in the head goes to the gauge.
  7. beastofablaze
    Apr 4, 2005
    441
    CA
    Cool thanks for the help guys.
  8. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    x2....
