2 different GM Corporate 14 Bolts??? (Small & Large)
Discussion in 'The Garage' started by az88k5, Nov 1, 2004.
  1. az88k5
    az88k5 1/2 ton status
    Oct 14, 2004
    258
    Prescott Valley, AZ
    I was wondering about the 14 Bolt and the clearance issues and looked at the technical page Axle Identification Chart and found two different 14 bolts. One looks like it wouldn't have as much clearance problems like others have talked about. 14 bolt being the AZ Rock Anchor. thinking about the 14bolt pros and cons. /forums/images/graemlins/dunno.gif
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    The smaller 14b is a semi-float one so it is not as strong as the full float. the 14bff can be shaved a good bit and gain about 1/2-1" of ground clearance, plus the parts for them are cheap.
  3. az88k5
    Oct 14, 2004
    258
    Prescott Valley, AZ
    Thanks it doesn't say anything about it be a semi-float or full-float. That answered my question. Definitely want the 14 Bolt FF
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    You want a 14BFF unless you are trying to stay 6 lug and/or you are running smaller tires and are worried about weight/ground clearance.
