2 Fabricating questions
Discussion in 'The Garage' started by bad_bo_ti, Feb 19, 2003.
  1. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    ok first one. on rear shock cross member like people are making, how many holes should i put in mine and where should i locate them?
    second one. on the zero blocks when makin my own. how much do the top corners need radiused? and what is the offset for the holes to offset the axles?
    thanks chris
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    If you can lift up the rear of the vehicle with the shocks disconnected. Then compress them about 1" or so and angle them in until the shock eyes line up to where the ideal mounting place is. This way you know you have full droop and you will most likely have more than enough shock left at bump. Hope that helps ya out some.
  3. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I put a .200" radius on the ones I have made. Seemed to work pretty well The offset is determined by how much you want to move your axle. If you want to move it 1", put a 1" offset in it.
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Poster: bad_bo_ti
    Subject: Re: 2 Fabricating questions
    MOO had a pic of theirs online. Should help you to get started.
    0.250
    -- Mike
