2 fabrication q's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dheavychevy38, Feb 5, 2003.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    2 fabrication q\'s
    Has anyone ever made there own shackle flip tips and pics would be great ???
    Has anyone made there own sway bar disconnections????? /forums/images/graemlins/k5.gif /forums/images/graemlins/truck.gif
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Re: 2 fabrication q\'s
    Here is mine...
    Rene
  3. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Yes,
    and No.
    I will try to get you some pics of the shackle flips, they are simular to ORD's but are shorter. 1-1/2" and 1-3/4" lift versions that I made for myself and TJ to level our K-5's and get better flex. I already had full lift springs so ORD's would have been too tall. Starting with 5x3 angle at the frame, using flat bar and a 3-1/2" OD tube for the shackles worked pretty well.
    I dont think I would even attempt to build sway bar disco's. For the price Watson sells them for it is not worth the effort. Just buy them slap them on in about an hour and save the rest of the weekend for something else. /forums/images/graemlins/thumb.gif
  4. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    Rene, how much lift did this set-up give you. Looks good, me like!
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    That netted me 4" of lift. I had 4" blocks before...
    Rene
  6. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    I did a bolt on shackle flip (borregok5 Helped with plans) and I am looking at doing disconnects for a friend. Here are some pics of the flips they are 3/8th plate steel.
  7. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    I made my own sway bar disconnnects. I don't have any pics, but they are like the ones that ORD makes. Here's a website that has plans for home-made ones: http://www.blazinobsession.com/sway%20bar%20quick%20disconnect.html . I don't know how they'd hold up though. Sway bar disconnects are completely worth it though. Good luck. /forums/images/graemlins/truck.gif
  8. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    BYB and TRUSTY, looks like you both moved the factory mount forward some. How much was it moved forward? TRUSTY, what is that shackle from? It looks longer then a factory chevy one.
  9. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Believe it or not mine is in the stock location I needed new ones and replaced them when I put the flips on. If you use the ford springs you have to move them which is what trusty is using I believe.
  10. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    Yea, now that you mention it seems I recall seeing the long thread about his f150 swap. I guess those shackles came of the furd.
  11. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I moved my shackle hanger mount back 2 1/2" and used the 57" Ford springs. The shackle I extended 1 1/2".
    We did the exact same shackle flip on my buddy's 89 Blazer using the stock hanger location, the stock length shackle and the stock 52" rear springs and gained 4" of lift.
    rene
  12. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    That flip came out pretty good! The 3/8's plate was the magic number for the geometry change top to bottom. Looks beafy! /forums/images/graemlins/thumb.gif
  13. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    It worked out great allot easier than trying to bend them. I have not tried them out on my truck yet but I used a buddy as a guiney pig first and he loves them I think I'm gonna cut the corner off to round it off more for a better look. Thanks again for the plans on how to make them. Ryan
