2 inch body lift question
Discussion in 'The Garage' started by eshorvath, Jul 11, 2004.
  1. eshorvath
    eshorvath 1/2 ton status
    Jun 20, 2002
    373
    Southern Oregon
    Im debating on giving my k-5 an additional 2 inches by doing a body lift. besides putting in the 2 inch spacers, what else is going to be done? Lengthened tubes? Steering? I want to do this all at one shot, can it be done in a day?
    Eddie
  2. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    1 day by yourself, maybe with air tools, you will have to lengthen shift linkage, and readjust your Ebrake cable other than that should be ok /forums/images/graemlins/waytogo.gif
  3. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    and removing the lower center section of the fan shroud
  4. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    I have a manual trans, so no linkage, how hard to adjust the linkage of the transfer case?
    Eddie
  5. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    no adjusting. Just make sure the shift levers are clear of the floor pan. Might have to trim a little but most likely not
  6. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    If your tailgate has lift-assist springs they may interfere with the lift. You might need to disconnect them for a 2" lift anyway.
  7. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Yep and it will look goofy too...also you will find out how heavy that tailgate is. /forums/images/graemlins/smile.gif
    After while that 2" gap between the body and bumpers will drive you nuts. Took me about 8 hours to lift both my bumpers the right way.
