2" lift, 33's, no trimming?
Discussion in 'The Garage' started by mtrdrms, Apr 4, 2005.
  1. mtrdrms
    mtrdrms 1/2 ton status
    Mar 14, 2005
    312
    Torrington, CT
    will it work with no rub?
  2. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    should... I have like 5 inches of clearance between my 31s and my fenders with a 4 inch lift... you should be good to go.
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    No/maybe. I ran 32's and 2" of lift and rubbed. They were 32x11.5x15" BFG AT's that measured 31" actual height. I also did not run a swaybar though.
    Harley
  5. dyeager535
    26,979
    Stock wheels? Tire width? Suspension? All matter as to whether 33's will fit with no rubbing.
    I've got 33's with no lift/no trimming and I don't EVER rub.
  6. mtrdrms
    Mar 14, 2005
    312
    Torrington, CT
    can someone post pics of this combo if you have it?
  7. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    I run 33's (actually 285/75R16 on 16 x 8 rims) with no lift and no rubbing. Just had to bend back the bottom back corner on the fender lip a little bit with the 5 lb sledge. But not enough that you can tell I did it.
  8. kennyw
    Jun 9, 2002
    13,223
    94
  9. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I used to have 2" on my truck with 33's (BFG AT's on 10wides) and it rubbed if u flexed it pretty good I got 4" now and that defiantly solved the rubbing problem. A friend of mine used to run no lift and 33's and his wouldent rub either but thats because his spring would bottom out on the bump stops before they could rub :D
  10. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    I have 33's with 2.5 inches of lift. No rubbing. Sorry, can't figure out how to make pic work.
  11. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    here is my bro in laws blazer 33s no lift and no fender trimming and trust me if he hit his fenders they would crumble they are mostly bondo!
  12. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    3" body and 33x12.5 on 16.5x9.75 and yeah... rubbed... even banged the tire into the fender and buckled the fender.... hit a rut from someone with 38's... this is about 1994 ish... :grin:
    pick on my mullet and I will smack you!!!!!
    this is 1991 with same size tires and same rims... but 0 lift
