2" lift question
Discussion in 'The Garage' started by tiger9297, Jan 5, 2005.
  1. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    Have a '90 K5. want to lift 2". was thinking of 2" in front and 3" blocks in rear to accomodate the rear sag. what is the cheapest way to lift the front 2"? I see some hangers that will lift it 2" but they are close to the price of new front springs. could you just make these? I don't do alot of wheeling so it's mostly for looks. opinions?
  2. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Get the springs.
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    2" isn't even going to give you "a look" i'd go at least 4", my buddy did his 4" after i talked him into it, he only wanted like 2-3", then he saw mine after i lifted it 4" was happy with, not too high, not too low, then you can throw some 33's on it with no problems,,looks real nice.
  4. tiger9297
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    I am running 33x12.5's on it now. I want to lift it but I don't want it too high. I just want sort of a sporty look. Not sure if 4" would be too high. Actually that is why i want to know of the cheapest way i can lift it 2". why i was wondering if i could just make some hangers that would give me 2" of lift and buy blocks for rear. If I want to go 4" then I won't have much money tied up in a 2" lift kit.
  5. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    you could get a 4" shackle flip in the rear, and a 3" spring up front. wouldnt be that expensive, and still be done right.
  6. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    4" and 35s always look great.
  7. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i dont know how a shackle could raise it 2" in the front. it would have to be 4" longer than stock and that would make your pinion point at the ground.not to mention ruining your caster angle.
    do it once and do it right. i personally think 2" is perfect for 33's. 4" is best with 35's. one thing to consider is additional problems w/ added lift.
    my blazer w/ around 3.5" lift has driveling vibes that i cant get rid of. i've tried all the tricks,and i still get vibes above 70mph. the only thing i think will cure it is a CV shaft, which costs 400 by itself. when i had 2" lift i was able to cure it with shims.everybody's experiences are different, so it might work out ok, might not.
    anything over 2" will also most likely require steering mods, mine did. not to mention longer brakelines and shocks.
    if there are any other blazers in your area that you like, ask them about their lift, even better go for a ride or drive it. i noticed a big difference in handling on the freeway with only 3" of lift. good luck.
    you could also post a thread asking for pics of trucks with 2-4" of lift. people around here are usually pretty eager to show off their rigs.
