2" lift steering problems
Discussion in 'OffRoad Design' started by cdh, Jul 27, 2004.
  1. cdh
    cdh Registered Member
    May 6, 2002
    69
    Gilbert, Arizona
    2\" lift steering problems
    I installed my tuff country 2" lift and ORD greasable shackles and bushings on my 89 Blazer and I am having steering problems. With no steering correction the draglink made a snapping noise when I turned the wheel, and it seemed like the front end was binding up offroad. I went to Offroad Unlimited, they looked at my draklink angle and sold me a raised steering arm (for a 4" lift but they said it would work). It fixed the snapping noise and it's not binding anymore, but the bump steer is terrible!
    With the raised steering arm the draglink is pretty much level. Should I have done a drop pitman arm instead?
    Does it make a difference if the front springs are 2" lift and the rear springs are 3" lift?
    Thanks for your help!
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Re: 2\" lift steering problems
    I had 2.5" Procomp springs ,and didn't do anything to the steering correction. I just took it to a alignment shop. That 4" raised arm is too much. I would left it stock.
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    It really doesn't matter how much lift you have as long as the draglink is near paralell, so if you have a raised steering arm and now it is paralell then thats good but if it angles upward some thats not good and you should remove it.
  4. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    With the TCI 2" springs, you shouldn't have a problem but a better fix would be a 2" drop pitman arm rather than the 4" lift arm. With a leaf spring that has some arch to it, you want the draglink to have a little down angle on it. The "flat draglink" myth is just that, a myth. For the geometry to work right, an arched spring demands a bit of downward angle on the draglink so that when the axle moves up and back the end of the draglink does the same thing.
    If your draglink is going uphill you need to change the arm out to put the angle back in it. You should check the angles out by drooping the suspension with the steering unhooked, then make sure that it will hook back up without binding. That's really the only way to check it out for sure.
    We have the drop pitman arms, they're $95.00 and are actually a lot easier to install than a steering arm.
