2" longer front driveshaft (NP205 to 10-bolt)?
Discussion in 'The Garage' started by guido666, Nov 8, 2005.
  1. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    Is there a stock shaft from another truck, tranny, etc. that is a couple inches longer then mine? I have a '79 Blazer with a SM465/NP205 and after my BDS 4" lift the front shaft is way too short. At full droop there is at least 2" u-joint to yoke gap with shaft fully extended! I don't have $300 for a new one, and calling around they say it would be that much to lengthen mine (another beef altogether). Any other suggestions? I just want 4WD for winter, I can buy fancy (expensive) parts next summer.
  2. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Anyone? Even a confident NO would tell me I'm screwed and have to come up with the $$$. Someone please help.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the sm465/np205 is the shortest front driveshaft GM used. you can probably find a th350/np205 or a th350 np203 driveshaft and it may be the right length.
  4. Janitorjim8
    Janitorjim8 1/2 ton status
    Feb 21, 2005
    215
    Illinois
    or if you just need a quick fix try a driveshaft spacer that goes between your t-case and driveshaft. they sell them at 4wp i beleive. when i put my lift on at first the shaft didnt fit in there but sprayed some pb blaster and let it sit and it slid out just that little bit that i needed
  5. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Awesome! I'll look for those spacers, any idea how much?
    Those other longer driveshafts mentioned, will they have the 4-bolt flange on the one end?
    There is a good 2" gap when the axle is at full droop. I just now thought about it but it may be even more in off-camber situations if the driver's side wheel forces the passenger side (with the diff) down just a little more.
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    as long as you get them from a 76 (or 77) and newer truck it it has the 4 bolt flange
  7. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Will an '89 front shaft work too? (Just double checking).
  8. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    it will work, will have the 4 bolt flange, but its way too long. IIRC its like 6" longer than a sm465/np205 front shaft. it is cheaper to have them shortened than to lengthen them.
