2" or 4" Lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CrazyCooter, Mar 17, 2001.
  1. CrazyCooter
    CrazyCooter Registered Member
    Mar 17, 2001
    8
    Germany
    Hello all, I have a stock 1983 GMC Jimmy with 31's. I would like to step up to 33's, can anyone tell me if I would need to lengthen my drive shafts with a 4" lift. I had a 6" Superlift, and I had to lengthen them, but this is a different truck. Thanks for the input. Tom
  2. you shouldn't have to lengthen your driveshaft for a 4". if you just want to run 33s you could go with a 2 or 2.5" lift. it will ride better then a 4"-just my personal experience. a 4" will allow for more flex. depends on what you are after and what types of wheelin you do.
    78, 350/350/203, 3/4 ton, 4" lift, 35" BFGs
    <A target="_blank" HREF=http://bluebeast.coloradok5.com/>http://bluebeast.coloradok5.com/</A>
  3. CrazyCooter
    Mar 17, 2001
    8
    Germany
    I won't be doing as much wheeling in Germany as I would in the states, and I still want to keep the driveability of my truck to handle these fun roads. I do get off road from time to time, but not enough to step up to a 4" or 6" lift and 35's. Thanks Tom
  4. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Re: 2\" or 4\" Lift
    Go with the 4 inch... here's the reason I say 4. When you ad a 4 inch lift.. easily you can easily fit 33's or 35's especially if you use 10 inch rims...
    If you go 2.5 and want to go w/ 35's eventually... Some trimming .. (i'm pretty sure) will be required to prevent rubbing.
    I was contimplating a 2.5 inch lift for the longest time.. but went w/ the Rough Country 4 inch Front/Rear springs and I'm so glad I went up 4 inches...
    Experience is something you don't get until just after you need it. <A target="_blank" HREF=http://www.rocko.coloradok5.com>http://www.rocko.coloradok5.com</A>
  5. WhiteWhomper
    WhiteWhomper 1/2 ton status
    Sep 23, 2000
    227
    Highlands Ranch, CO.
    Re: 2\" or 4\" Lift
    I run a 4" Rough Country lift with the stock driveshafts and have no problem. The 4" works great with 33" tires, but fender trimming would still be necessary for 35" tires. Myself, I decided to do a major fender hack and run 36" Swampers.
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Re: 2\" or 4\" Lift
    You will prebably have to lower your transfer case if you go with the 4", but I really like the way a 4" lift and 33s look, so thats what I'd do.
    90K5
