2 part - Wipers and Heater
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by swamp donkey, Sep 24, 2002.
  1. swamp donkey
    swamp donkey 1/2 ton status
    Apr 29, 2002
    186
    Thousand Oaks, CA
    My "truck in a box kit" (as like to call it) has been mostly put together and driveable for the last few months. The only parts that didn't make it into the truck (and thus still live in the previously mentioned box) are the heater and wiper parts - or lack there of.
    Here is what I need... HELP!!! I have no idea where to begin.
    1st: The heater. I might or might not have all the parts. Anyone out there know what I SHOULD have, and hove it SHOULD go together?
    2nd: Wipers. I see the motor, and some places where vaccuum lines should hook up, but I am missing those lines, and the switch. what a mess.
    Any advice, from anyone, on where to begin would be great. Thanks in advance, Dylan
  2. bdkmiller
    bdkmiller Registered Member
    Jul 31, 2002
    42
    NH
    Dylan,
    What year truck do you have? I just worked on the wipers on my '72. If you have a '72 then the vacuum hook up are actually the washer pump hook ups. The windshield washer runs off the wiper motor. I have a couple but none of mine work. They move but don't quite pump water. It shouldn't be too hard to find a switch. There are three wires, if I remember correctly, yellow blue & black. They control the two speeds on the wiper. I took my motor out & cleaned it up & now it works like new.
    As for the heater, I haven't done that yet.
    Hope this helps,
    Brian
  3. skyblazer
    skyblazer 1/2 ton status
    Oct 1, 2000
    209
    Houston, TX
    Dylan, I'm changing my heater box out right now and replacing it with a Vintage Air a/c system....just too dang hot in Houston! There are two main parts, the outside plenum and the inside plenum/controls. The outside part is a housing for the heater core and fan. It bolts to the exterior firewall. The inside part contains the valves to control air movement and the connections for air hoses to the defroster and floor vents. All control cables hook up to this part. PM me if you need specifics..maybe a call to run through the parts would help. Also, mine is all coming out today. Let me know if you need parts, I'd be willing to sell mine. PS....I think the LMC catalogue has a good breakdown of the parts.
  4. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Dylan,
    If you haven't already discovered the "Factory Assembly Manual" which is available from ChevyDuty, or LMC......that's a "must have" item for figuring out how things were "Supposed" to look.
    Lots of exploded views...it's basically the sheets that they used on the production floor to explain to people how to put the trucks together originally. The only problem with the book is that it seems to have been "shuffled" before they glued it together....nothing is in a logical order, so you'll have to search for everything! I have about 100 post-it notes in mine to bookmark the things I want to find later!
  5. swamp donkey
    Apr 29, 2002
    186
    Thousand Oaks, CA
    Good to know tha vacuum lines are only for the washer. That makes things a lot simpler. Three or four wires I can handle no problem, and I assume LMC or CHevy Duty has the the handle. Thanks.
  6. swamp donkey
    Apr 29, 2002
    186
    Thousand Oaks, CA
    There is a big black box hooked to the fire wall, so I at least have that part. I am going to get the Book that greg72 mentioned - that should clear things up.
    How does your new AC work? does it replace all the factory heater stuff as well? I live in Los Angeles, and next summer I may try to add AC. Let me know how the install goes.
  7. swamp donkey
    Apr 29, 2002
    186
    Thousand Oaks, CA
    I am ordering the manual today. Thanks (again) for your input. /forums/images/icons/smile.gif
  8. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    The manual is great, I just got one a couple of weeks ago. They aren't labeled very well though. You should also pick up a wire diagram, or one of the members scanned them and posted them to a web site, but I don't have that URL bookmarked. The diagrams in LMC can be useful too.
  9. eshorvath
    eshorvath 1/2 ton status
    Jun 20, 2002
    373
    Southern Oregon
    I may be intetrested in parts for the heater box. What year do you have?
    Eddie
  10. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    Other Info Source
    To go along with the factory 'assembly' manual they also have in reprint a factory 'service' manuals available for each specific year.
    Check e-bay for those, they seem to pop up alot on there.
