2-piece driveshaft- VIBRATION FINALLY CURED!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Can Can, Mar 11, 2003.
  1. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I have been trying to solve a minor vibration issue with my 83 1/2 ton truck for the last couple of years. The vibe started after I replaced the rear u-joint(the remaining two were still good so I left them in). I learned to ignore the vibe until I replaced my tires with new "C" load LT tires. The firmer tires made the vibe almost unbearable at 40-55 MPH.
    Anyhow, after a lot of research and some good advice from drivelineman(Thanks, Jess!!!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif), I took my truck into a local driveshaft place and let them take a look.
    I can't exactly recall what the service manager told me, but it was along these lines: Apparently during the 80's GM didn't "true" their driveshafts before they were installed, Instead, they could compensate for minor warpage by adjusting where the u-joint was installed in the yoke. When you swap in an aftermarket u-joint, you can't offset where it sits in the yoke and can throw the balance out. I may not have explained that properly- maybe someone can describe it better....... /forums/images/graemlins/tongue.gif
    Anyhow, the shop replaced all the u-joints while the driveshaft was out. They also straightened the shaft and balanced it. Can I have a "Halleluja"??? /forums/images/graemlins/wink.gif For the first time in 3 years I can drive down the highway and not feel a vibration!!!!!!
    Sorry for the long post, but I thought a couple of you may be in the same boat and could learn from my experience. /forums/images/graemlins/thumb.gif
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    interesting, i hope someone that knows more about the u joint position in the yoke deal reads that and will comment on that, im curious to know about that.
    glad vibration is fixed finally /forums/images/graemlins/thumb.gif
  3. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    glad i could help- Jesse
