2 piece driveshaft with bearing- ditch it?
Discussion in 'The Garage' started by monster man, Oct 7, 2005.
  1. monster man
    monster man 1/2 ton status
    Oct 20, 2003
    282
    Reno, NV
    hey all, I'm trying to decide what to do on this driveshaft when I lift my K20 (this weekend? we'll see). It's got the stupid carrier bearing, am I going to be able to leave it as is for now? I'm sure it would be fine with a 4" lift if it were one piece, as the angles would barely change, but it's two piece, so the rear half is like Blazer length. Should I automatically count on having it lengthened into a one piece? At some point, hopefully soon, the wheelbase will be shortened at least 20", so I'm not sure what to do right now. Is it easier/cheaper to lengthen or shorten a driveshaft?
    Is there any chance I'd find a 1-piece at the Pick n Pull that I could swap in, or were most longbeds 2-piece?
    thanks
  2. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
    change it out to one piece shaft. i had a 1 ton with the 2 piece shaft went 1 no problems. that was so the factory could use up some left overs or also the truck was to be a 2x4 but was switched to 4x4 from the factory.
  3. mtnman
    mtnman Scrap metal fabricator Premium Member
    Sep 8, 2005
    2,087
    31
    On the farm , Missouri
    2 piece shaft
    Lower the carrier bearing about half the lift height. A piece of 2" tube and a couple of extra bolts - at least that is what I plan on doing as a no buck solution. :hack:
  4. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    If it's 1350 and fixed yoke at the t-case I'll buy it from ya!
  5. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Nothing wrong with a two piece 1350 shaft as long as the angles are in spec.
    Two piece shafts were most likely used on long wheel base trucks to keep from having a very thick , or very large diameter tube in a one piece shaft. There is a rule of how long a given shaft can be with out bowing under load therefore it was probably more cost effective to offer a two piece set up instead of a beefy one piece.
    If you are hell bent on using a one piece shaft look for an older K-20 that used a 4.5" diameter one piece shaft with 1350 joints. I have seen these shafts get the snout beat out of them with good results.
    In the end a two piece set up is not weaker by any means it is just a different way of doing the same thing.
    HTH , Tom
  6. monster man
    Oct 20, 2003
    282
    Reno, NV
    thanks guys, I may lower the carrier bearing- Pick-n-Stick had NO 4wd 3/4 or 1 ton trucks to steal a shaft from. They must pick that stuff before putting it out to the yard. There was a Suburban but the shaft was bent in two :( DOn't want to spend money on a whole new shaft either
