2 piece rear drive shaft
Discussion in 'The Garage' started by RootBreaker, Nov 16, 2004.
  1. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    anyone have experience with these? I drove my truck tonight.. went down a highway and while accelerating... the truck seemed to start hopping... I do know that when it was lifted the stock shaft was used. a 2 piece.. Does anyone know the total length of the splines where the 2 meet? I have about 3" sticking out and when I push on the outter shaft it seems that there is play.. could that have done it? also there is that bearing that keeps the 2 shafts together... it has some play in it but seems that it might supposed to as it is not a solid structure.. I know that I am probably confusing you all... but I dont know where to go with this....
    I also noticed alot of steering play.. when driving down the road.. I can wiggle the wheel back and forth a bit and the truck goes straight... I have a new tie rod.. completely new and since I have xover steering from ord... all that is new too!!! dunno.. tired and dunno... /forums/images/graemlins/dunno.gif
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    The carrier bearing will have side-to-side movement but shouldn't have any rotating play as far as I know. If there is any doubt about it I would replace it. We were getting some terrible vibes in the '68 and replaced the carrier bearing and it fixed most of them, it wasn't a very expensive part or a hard task if I remember correctly.
