2 piece rear main in place of 1 piece rear main
Discussion in 'The Garage' started by MudFlap, Sep 20, 2004.
  1. MudFlap
    MudFlap 1/2 ton status
    Dec 2, 2002
    250
    Winston-Salem, NC
    My buddy has a 86 K20 and it needs a motor, so it is supposed to be a 1 piece rear main seal. What has to be done to use a gm crate motor with a two piece rear main?
    Trey
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    All you need is the proper flywheel/flexplate , same tooth count as his original , just needs to bolt on to an older motor . GM sells these . You can bolt all his original accessories and brackets onto a one piece main motor . Piece of cake , its a small block /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  3. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    Thats all that I thought that was needed to be done.
    Trey
  4. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    One more question. Does anybody know or can somebody tell me any east way to check how many teeth are on the flexplate? Don't say count them, I am looking for an easier way than that, the motor is still in the truck.
    Trey
  5. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Most likely its a 168 tooth.
    A 14" flexplate is 168 tooth
    A 12.75" flexplate is 153 tooth.
    If your buddy has a "stock" starter. Its pretty easy to tell.
    A 14" will have a diagonal "staggered" bolt pattern.
    A 12.75" will have a parallel bolt pattern.
    14" Starter
    12.75" Starter (nose)
    Staggered
    Parallel
    John
  6. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    thank you
    Trey
