2 questions for you guys/gals
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dheavychevy38, May 20, 2003.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    I have a 89 k5 at idle it has to much fuel cause of all the black smoke ant 1/4 throttle it flutters what do you think it runs good other than that?
    I have a 8 inch lift 38's on a 1/2 ton truck any way to get more lift out of the front if i do a shackle flip in the rear ? /forums/images/graemlins/k5.gif /forums/images/graemlins/truck.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    ok, too much fuel at idle? its an 89? its tbi, right? sure all the plugs are working? lol... id check for correct spark.... and 38s on half ton? is it a mall crawler? lol broken anything yet?
  3. RClivin
    RClivin Registered Member
    Jan 20, 2003
    23
    Santa Cruz CA
    Question one:
    I dont know, I would say it was the diaphram in your carb but 87 and up are injected. I gotta say you need take it to the mechanic because it is controlled by computers.
    Question 2:
    you could go with longer shackles in the front but from what I have heard that makes your ride all screwed up
    I havent personally done it but it looks like a nice way for some extra lift.
  4. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    yes it's a tbi i am a mechanic but on concrete/ diesel equipment a and no i haven't broken my other truck except for the trans if i could post pics i would show i use it i have gone through 2 rear ends and 4 trans but the parts have been free so far
  5. BPS
    BPS Registered Member
    Mar 24, 2001
    28
    Sooke, BC, Canada
    check your o2 sensor and look for exhaust/header leaks
  6. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    "Ask" the computer what's wrong.
    Got a Haynes or Chilton manual? It will tell you how to jumper some wires and read the code.
    Good luck. Have fun.
