2 questions... Help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, Nov 29, 2000.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    How much (ball park figure) does a 700R4 weight dry? Need to know for shipping purposes.
    #2. With open diff and both rears off the ground, in park, if I turn either of the wheels how much play or rotation should I have before the driveshaft starts to turn? I was playing with it last night and it seems to be way sloppy.
    Don't you buy no ugly truck!
  2. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    700R, no idea. As for the diff's depending on what size tires you have, they will make the play seem like more the bigger the diameter, I would expect about 1/8 turn of the tire before the drive shaft turns. This will take up all of the small end plays built into the axle, spider gears and the ring and pinion. With a detroit it is more like 1/2 revolution
    I thought I was wrong once,
    but I was mistaken
  3. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    I've got 10 bolts, with the stock 3.42's. And 1/8 of slop is about what I've got. Just seems like it shouldn't be that much.
