2 questions one post: carb and heater core
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pornorob, Feb 19, 2005.
  1. pornorob
    pornorob 1/2 ton status
    Jul 12, 2001
    215
    ;jkl;
    i'm pretty sure it has a rochester on it and I cant get it to idle any slower. its idling at about 1100rpm and I've turned what I think is the idle adjustment screw(right side from the front knda near the bottom) far enough out that the linkage isn't even hitting the the end of the screw anymore. I was wondering if a faulty electric choke might be the cause but thats just a blind guess. I'll get a pic of the carb and post it later today for Identification purposes.
    OK question # 2 the hoses for my heater core are not connected so no heat. I was wondering how to connect them. I see one spot to hook it up on the water pump but I need to know where to hook the other hose up. Any hints or suggestions that will make my life easier are appreciated.:D
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Good way to test the binding choke theory is to take the choke off and see if it still idles really high.
    On the heater hose part, it can be connected to either the water pump, intake or radiator.
  3. pornorob
    Jul 12, 2001
    215
    ;jkl;
    here is the carb. I took the choke off and it didn't do anything. is it possible that it was rejetted with a jet that are too big? don't really know much about carbs just taking a stab in the dark.
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Where in the picture do you think the idle control screw is?
    BTW, that sucker is filthy. Go buy a can of carb cleaner and clean the outside and inside of that unit....
  5. pornorob
    Jul 12, 2001
    215
    ;jkl;
    I think thats where it is. (yellow arrow)
  6. Can Can
    15,552
    136
    Yup, that's where it is. You're saying that the screw is backed off so far it's no longer touching the linkage? Can you manually pull the throttle linkage back? Is there a chance that your throttle cable is binding somewhere?
  7. pornorob
    Jul 12, 2001
    215
    ;jkl;
    it takes alot of effort to pull the linkage any further than ii already is. the cable actually moves really easily. I may try disconnecting the throttle cale and see what happpens then.
  8. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Check all you vacume hoses and carb base for vacume leaks.
    Check to make sure the choke is open all the way and the high idle adjustment screw on the choke is not hung up on the high idle cam.
  9. Can Can
    15,552
    136
    Hmmmmmmmm.......never thought of that. Are you sure that the fast idle linkages on the passenger side of the carb aren't sticky or jammed up?
    Man, you really need to clean that carb......:deal: :rotfl:
  10. pornorob
    Jul 12, 2001
    215
    ;jkl;
    well I checked the high idle screw and all the linkage that side of the carb everything moves freely. disconnected the throttle cable.... no prob there. I've heard of spraying carb cleaner to find vacuum leaks. Can you use WD40( I don't have any carb cleaner) instead?
  11. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    Left side of the pic I see a spade connector that should be connected to the choke housing. Without 12 volts there the choke won't open and the fast idle won't kick down.
    Rene
  12. pornorob
    Jul 12, 2001
    215
    ;jkl;
    that was disconnected to check to see if the choke was working. it is connected now. I manually moved the linkage so that it would kick down from high idle and it made no difference. I'm at a loss.
  13. personaltrainer
    personaltrainer 1/2 ton status
    Nov 4, 2004
    178
    Atlanta GA
    No wd40 - go buy the carb cleaner. It's cheap and really works well. You should always have ity around anyway. Spray around the carb base, intake manifold base and don't forget the exhust manifold as well. Good luck
  14. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    That looks like the M2M series 2 barrel. If you have a chilton or haynes manual you can look under fuel and exhaust systems for step by step instructions.
  15. pornorob
    Jul 12, 2001
    215
    ;jkl;
    yeah I need to get me one of those....... manuals that is ....
  16. dyeager535
    26,979
    Thats a rochester Q-jet. (4 barrel)
    Is the throttle kicker by any chance still sticking out and not retracting? It's the solenoid above the idle speed screw.
  17. Can Can
    15,552
    136
    Yeah, that's another possibility, eh?
    Pornorob- the solenoid that Dorian is referring to is the the little can with the blue wire/red spade connector running to it. If you look carefully, there's what looks like a bolt head touching the little green-colored actuator arm.
    I'm pretty sure that the solenoid kicks the idle up when the air conditioner or defrost is turned on. If it's "stuck on", then the idle will be stuck in the elevated throttle position, which may explain why you can't get the sucker down to curb idle.
    Sorry, I don't know how to troubleshoot the solenoid. I DO know that last year I didn't fully turn my A/C off and my idle kept kicking up for no reason, or so I thought.....:doah:
  18. Cricket
    Nov 29, 2004
    8,224
    Colorado
    It Just Gets Worse
    :eek1: How in the friggin heck did I overlook that. Embarrasing, friggin embarrasing - Time for early retirement.
    http://www.sptimmy.com/sounds/timmyshhh.wav
  19. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Do you know your advance hose is disconnected ?
  20. Can Can
    15,552
    136
    That's what I call an eagle eye, Pauly!!!!
    Figure it may have something to do with wierd idle????:rotfl: :rotfl:
