2 questions
Discussion in 'The Garage' started by 86chevybanshee, Jun 17, 2004.
  1. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    i just bought a 2 inch body lift for my truck. i bought it off my friend who opend it but never installed it, its for a blazer and has 10 pucks, is that the right amount?, also there is a pin about 1 1/2 inches long, whats that for? also who makes the softest 2 inch rear springs and 6 inch fronts?
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Don't know anything about body lifts... but for springs, TC or BDS are the softest springs /forums/images/graemlins/waytogo.gif
  3. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Yes 10 is correct. ANd the pin is probably to extend your shifter linkage. With a 2 inch BL your linkage will be too short to drop into 1st. I ran a die over my linkage and rod and put a nut between them to hold them together. That was beofer I could weld. Now I would just weld it toegther and it will wor /forums/images/graemlins/thumb.gifk fine.
