2 questions
Discussion in 'The Garage' started by original balzer, Jan 2, 2005.
  1. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    first off what does zero rate add a leaf mean ( i cant get my head around that)
    second does anyone else run without a front sway bar i dont have a sway bar on mine now and it seams stable at highway speeds but ALOT of people seam to press how dangerous it is that i dont run a sway bar
    willow
  2. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    a zero rate add a leaf its more or less a block that bolts directly to your leaf spring. it gives you the lift that an add a leaf would give but does not increase the rate of your spring. more rate=stiffer ride
  3. original balzer
    Nov 17, 2004
    4,660
    roosevelt utah
    AHH ok i have a 4" rancho lift my little bro just bought a 6" pro comp and had rancho add a leaves so im going to swipe the add a leaves to put in my 4" packs and was just wondering what a zero rate was lol so basicaly its like cutting some older thick overload (bottom) springs then correct?
    willow
  4. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    to answer your second question. No you don't need the swaybar. Lift springs are a bit stiffer, and if it feels ok driving then trash the swaybar. Most people here don't run them at all.:)
