2 questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chiefheaphy, Apr 13, 2007.
  1. chiefheaphy
    chiefheaphy 1/2 ton status
    Mar 13, 2007
    632
    East MASS
    what is the best way to go about dissasembling the front axle u-joints? I know there are usually c-clips that need to come out, but I either cant find them or dont know where to look. There oem spicer 1986 1-ton.
    I'm getting sick of wire brushes on grinders and drills to clean rust. Is it worth building my own or buying a sandblaster, or does anyone know of any paint prep/rust remover procedures that work well?
    Thanks,
    Heaph
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    The C clips on axle shafts are on the inside of the cup not outside like the driveshaft.
    For rust I use different things for different places.
    On thread and important parts I use PB blaster or any rust eater spray.
    On steel or cast pieces that just need cleaning I do sand blast or lightly wire brush then paint with rustoleum.
    A sand blaster is definitely something I don't regret buying, in fact I regret buying a small portable blaster, I need to get the big pressurized tank.
