2 questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, Oct 30, 2000.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Just replaced the rotors and pads on the front. Now they are squeking only when I dont have them applied. Help!
    #2, 90 jimmy, NP241c. When I pull my rear drive shaft out, is there supposed to be any fluid coming out at all (while sitting level)?
    Don't you buy no ugly truck!
  2. NH77Jimmy
    NH77Jimmy Registered Member
    Oct 25, 2000
    16
    Manchester, NH
    I've had that experience with the brakes. It turned out to be the pads against the caliper. I was able to quiet it by getting some adhesive from a local parts shop (they should know what you're looking for). I applied to the caliper piston and the back of the pad. No more noise.
    Shawn
  3. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Thats what I was thinking. When I took the old ones off, there looked to be some sort of remnants of something like that. Ok, guys I still need some help with the TC fluid.
  4. CK5
    May 19, 1999
    21,627
    704
    CO
    #1 Fairly common, take off brake pads and spray the back of them with some anti brake sqeek (adheasive), buy it at Pep Boys, Checker, etc..
    #2 You will most likely get fluid to come out if you pull the shaft because it is a slip yoke - unless you installed a fix yoke kit.
    5,000 Pounds of American Rolling Steel
  5. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Now you see? Thats where the problem is. When I took me driveshaft out to swap u-joints, the beast sat there for over an hour. Not one drop of fluid came out. Maybee TC fluid is low??? Just got this beast a little while ago. Haven't had the time to get into that cavity yet.
