2" rear lift springs 52" eye to eye
Discussion in 'The Garage' started by cybrfire, May 25, 2004.
  1. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    2\" rear lift springs 52\" eye to eye
    Does anybody know of anybody that makes 2" rear lift springs. Not add a leafs or blocks an actual spring?
    Anybody? Obviously Alcan, Eaton or somebody could but what about the regular manufacturers.
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Re: 2\" rear lift springs 52\" eye to eye
    Rancho 86209, or 86211
  3. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    got a website that lists them. I haven't been able to find anything. Oh yeah While I was thinking about it I called Eaton spring and they can get me the springs for 260 a pair. Thats a 5+1 pack or 6+1. Not too bad I guess.
  4. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    ORD has got Tuff Country's in 2" 3" 4" 6" for the 52" stuff...
  5. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    350 a pair seems a little steep doesn't it?
  6. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    yes also check with skyjacker they have I believe a 2.5" rear spring.
  7. Kyle89K5
    2,273
    OKLAHOMA
    Now you are getting down right PICKY aren't you /forums/images/graemlins/grin.gif
    You asked for a spring, I found you a set /forums/images/graemlins/grin.gif
    I do think that is pricey, especially when you consider that the spring rate may or may not be in line with a front end on a truck. Did I just say front end? That must have been me thinking of my future plans for my truck.......
    Kert, BTW, I need to hit you up about a couple things, PM on its way /forums/images/graemlins/thumb.gif
  8. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    That is where I'm going. 52's on the front however, I want to keep it as low as possible and still clear the 44's so, here is where I am. 2" lift springs may clear but they are a little more difficult to resell if I were to go to 4 link some day down the road. 4" lift springs would surely clear but that is a total of 8" lift. Little higher then I want to be. Damn, I am getting picky.
  9. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Why not go with a stock spring for 4" lift, 1" zero rate, plus a 1" body lift? Then you can get by cheap and not have to worry about selling the expensive springs later. /forums/images/graemlins/thumb.gif
  10. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Kinda been thinking along those lines as well kennyw. All good solutions. Just having trouble picking one for some reason. I can see my future and it has a lot of spring changing in it. Now where is the little clicky guy with an impact? sawzall, torch, grinder, no impact.
  11. kennyw
    Jun 9, 2002
    13,223
    94
    Well if something cheap helps to answer a question for you I have a set of stock 52" springs and a clutch fan to trade for some computer parts /forums/images/graemlins/whistling.gif
  12. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Sounds good. Bring them along! How many leaves in the pack? more rust than steel, equal amounts rust and steel or mostly steel?
