2 speed rear end
Discussion in 'The Garage' started by 77crewcab, Jul 2, 2005.
  1. 77crewcab
    77crewcab 1/2 ton status
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Just wondering if anyone has considered installing a 2 speed rear end out of the 6/7000 series trucks to use on a tow rig? There is a GMC 6000 at the local yard with a 465/2 speed rear and shile the rear axle is pretty big it got me thinking about if it could be done or if it would even be beneficial. Any thoughts?
  2. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    it would allow you to get a lot larger load rolling with a smaller engine. ie 350 :D although my grandfather has a 70's c60 w/ 350/465 straight geared rear! And yes I used to haul the full 6 yrds of sand in that truck just like his other 80's c70 366/5-speed/split rear would. I was even able to accelerate faster with the "little" truck than another guy could with the bigger truck. LOL so I guess it's all about how you drive what you have and what you need it to do.
  3. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Honestly just thought it might be a cool thing to have for a tow rig to basically have 8 gears (with 465) and have some LOW gears to get rolling similar to how a semi does. With experience driving both style axles in the same size truck do you think it would work well for a daily driver/tow rig on a crewcab?
  4. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    well seethe way I always use a split rear is start off in low range, shift through gears in low till yer top gear, then shift the rear up to high range. And yes I think it would work well. Have considered it myself :D
  5. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Thats what I was thinking too. Should certainly help with the gear spacing problems of the 465. I guess if it isnt enough a gear vendors could always be added. Seems like an interesting idea anyway wonder how much fab work would be required.
  6. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
    these 2-speeds axles , how do they work ?
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    vacuum
    they are big
    huge
    overkill
    personally i wouldnt do it
    but good luck
    i have owned a few big trucks so i know about them and have driven them
    the last oen i had was a 53 6400 the GVW of the thing was 16,000
    thats the largest you can legally drive in IL on a regular drivers license
    the vacuum system for the axle ranges was broken,
    its a PITA fixing that when it happens, i never got to fix it and ended up selling the truck, it was in good shape otherwise, clean truck and all, i only gave 500 for it and drove it away
    its still running around town, saw it last week, i had it a couple years ago,
    heh
  8. Lonnie P
    Lonnie P Registered Member
    Feb 7, 2005
    28
    Pittsburgh, PA
    Unless you are getting the rear from a diesel version of the truck, it will likely be geared very steeply. Most range from 5.29 to 7.17 in high range. For low range multiply by 1.36.
    I have one with 7.17:1 & it is 9.77 in low.
    You better have a very tall tire or plan to go slow while towing.
