2 stroke leak down tester???
Discussion in 'The Tool Shed' started by kgillyk5, Jul 6, 2006.
  1. kgillyk5
    kgillyk5 1/2 ton status
    May 29, 2003
    1,830
    Fultonville, NY USA
    Any dirtbike gurus?
    Anyone make there own leak down tester? My kx125 is getting noisy and probobly needs a new piston ring but I would like to check for air leaks before I tear down. I cant believe you need $250+ for what looks like a turkey baster and 30 bucks worth of adapters and gauges.:eek1:
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Is there any reason a typical leak-down tester for a truck won't work? Those are in the under $100 range. TAV-08015
  3. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
    cars and trucks run 14mm threads. jap bikes run 12mm threads. most kits dont come with that one.
  4. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    You can buy rings for a lot less than the testor. Hell you can get all the gaskets (I use permatex aviation gasket maker on the center case) and crank seals plus rings for under $250 IMO and then you have new rings and no leaks
    also I like to change the reeds at the same time as the rings
  5. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Oh.
    Well, that's not too difficult to solve. Old sparkplug; meet air fitting.
  6. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    a piston and rings will cost you 70 bucks, with gaskets and exhaust orings your looking at around 100-125 bucks. The thread on the oplugs is the same. Just do the top end. it will take you half a day and will be WELL worth the money...
  7. K5Kell
    K5Kell Guest
    Was just doing a routine top end the other day when I got in there and found two cylinder cracks on either side of the exhaust port:doah: . just a reminder that a quick rebuild on these bikes can quickly add up due to worn out/broken parts, but at least you will catch it before it takes out other things:wink1: . Good luck.
    -Kell-
