2 Stupid Bodylift Questions...
Discussion in 'The Garage' started by dhdescender, Jun 30, 2003.
  1. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    Right now I'm running 1 hocky puck+3"steel block for my bodylift. I have none of the original body rubber, it all went to hell a while back.
    I want to order a 'real' body lift kit, 2 questions:
    Are the poly bodylift mounts supposed to sit on stock rubber mounts, or do they replace them?
    If I order a 3" body lift kit, and I have no stock rubber mounts, does that mean I'm only lifting the truck 2" because of the lost 1" tall OEM rubber?
    Thanks, I know its dumb, but I need to know for where my bumper will be located.
    /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/thinking.gif
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Yes, your supposed to run the original body mounts underneath the body lift pucks. They are about 3/4" thick so you will loose some body lift without them and pick up a lot of vibration.
  3. dhdescender
    Aug 10, 2002
    628
    Are new mounts easily ordered from GM?
  4. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    gm will sell you rubber mounts and charge a mint. I went to a local performance shop and got a full poly mount kit for $79.
  5. Anthonviking
    Anthonviking Registered Member
    May 25, 2003
    44
    Varnamo, SWEDEN
    Check out LMC truck on www.lmctruck.com and order a free catalog online. They got body to frame mounting hardware ...
  6. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    ORD will sell you a body mount kit http://www.offroaddesign.com/catalog/bodymounts.htm. I bought mine and installed it weekend before last with a 1" body lift. Actually, Okiemuddog did most of the work, I was in stiches, literally /forums/images/graemlins/grin.gif
    It's not really advisable to run with out the body mounts, the vibration alone will be a mess. You want SOME kind of body mount in there...
  7. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    or check for a place that sell's auto body parts. igot mine at one for about $50.00, all of them for a 79 blazer. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
