2" susp. lift... Do i need new shocks???
Discussion in 'The Garage' started by IL84JIMMY, Apr 20, 2004.
  1. IL84JIMMY
    IL84JIMMY Registered Member
    Feb 24, 2002
    29
    Northwest Illinois
    2\" susp. lift... Do i need new shocks???
    I am thinking about adding two inches in the form of leaf springs up front and back. I recently replaced my stock shocks. Will i need to replace them again? Or is two inches a small enough amount that i can get away with keeping them? thanks /forums/images/graemlins/ears.gif
  2. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Re: 2\" susp. lift... Do i need new shocks???
    With 2" you could probably get by with stocks... but I would go with someing else because your limiting flex, if you just dont wanna spend alot of money on them go to auto zone and get the gabriels(sp) there cheap and I have heard there a good shock
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    [/ QUOTE ] +
    They are a good shock. I run them in the rear. These are the same as many aftermarket shocks, my front Pro Comp shocks have same type can and markings as my rear Gabriels. I have no problems with the shocks. /forums/images/graemlins/k5.gif
  4. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    You do not have to change your shocks, but for a $130 you could have 4 new es3000 pro comp shocks.
