2 types of GM SRW D60 hubs?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by az-k5, Mar 29, 2004.
  1. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I was changing out the hubs on my mom's 1976 1 ton short bed crew cab (that's right we built a short bed) tonight and ran into a small problem. There is no recess slot for the large C-clip to fall in. Ya know the one that holds the actual hub back. With out this recess slot the locking cap has about an 1/8 of horizontal play when bolted on (the stub shaft c-clip is the only thing holding it in). Is this a full-time hub that was poorly converted (PO was a POS /forums/images/graemlins/angryfire.gif). My 60 has the large C-clip so I assumed that this one would too.
    What do I need to do?
    (please avoid saying new SRW hubs -> that is probably the answer though)
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you probably could take one of your and both of hers to a machine shop and machine the groove in. /forums/images/graemlins/dunno.gif
    are you sure there is no groove? is it full of grease /forums/images/graemlins/dunno.gif
  3. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    I ran a small screw driver around it really hard and found nothing. I blasted brake clean in there till the metal was shiny again and no groove to be found. I sucks cause I thought the hubs were half junk (hoping to use them as trail spares). I can cut a groove in them if I have to.
  4. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    Man I thought I was the only one with those hubs. Sucks. I looked all over for that groove. Im just running drive flanges for now.
