2 vs 4 front shocks on a 90
Discussion in 'The Garage' started by chevyjeff, Jan 26, 2004.
  1. chevyjeff
    chevyjeff 1/2 ton status
    Dec 10, 2003
    118
    WYLIE TEXAS
    going to be swapping in a 3/4 ton combo on my 90 blazer. The 3/4 ton front diff. came with only one shock mount per side where as my stock 10 bolt front diff has dual shocks on each side. What are the benifits of dual shocks in the front vs a single shock. If I do some sort of fabrication is there a beefer afermarket bracket to use to mount dual shocks in the stock configuration
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well if both shocks are valved correctly to equal the dampening for your application ( to be like one big shock ), you would get better ride control and less shock fade. /forums/images/graemlins/k5.gif
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    4 shocks will limit flex a little more.. i have quad shocks currently and will be running singles when i get new shocks..
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Dual shocks will not fade as fast when bouncing through the desert. In most cases, you are just buying two more shocks.
  5. chevyjeff
    Dec 10, 2003
    118
    WYLIE TEXAS
    as far as drivability on the street which set up would be better. mine is mostly a d.d but will be used to tow the boat to the lake and occasional offroad (mud and trail no rock climbing).
  6. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    When I went from single shocks to quad shocks up front, I noticed a change in the handling. Less body sway and it seems to stick a little better to the road through turns. I didn't notice that it was much stiffer like some said it might do. I would run dual shocks up front for sure.
  7. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    [/ QUOTE ] I do, Right next to my 540" /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  8. dyeager535
    26,975
    Well designed single shocks are probably a better bet. Not sure if they were a gimmick for sales, or shock technology was that bad when the trucks were new, but I personally feel that my truck rides stiffer with duals than singles, although I've got the 3 leaf front springs on this truck, and my single shock '83 had two spring fronts.
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'm no expert by amy means, but I don't see any reson to run more then 1 shock per wheel. /forums/images/graemlins/deal.gif
  10. chevyjeff
    Dec 10, 2003
    118
    WYLIE TEXAS
    Doesnt some company make a dual shock mount for the axil housing? Dont really want to cut the one off the 1/2 ton 10 bolt because I will resell it or use it for another project in the future.
  11. dyeager535
    26,975
    Lower mounts don't need modified, because they use the standard single shock bracket, with a longer bolt that the outer shock rides on. (which bends BTW lol) There is nothing that supports the "outside edge" of the second shock.
    The upper second shock mount is the "additional" bracket in that setup.
  12. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    Sure, skyjacker and several others make a kit.
