2" vs 4" lift???
Discussion in 'The Garage' started by jd70ssclone, Mar 19, 2007.
  1. jd70ssclone
    jd70ssclone 1/2 ton status
    Nov 29, 2006
    125
    baltimore
    hey guys i just bought a set of 33 allterains for my 86 k5 but in order to put them on i must lift it, i was looking at the 2 and the 4inch kits from rough country and was wondering what you guys think i should do i only plan to do moderate fourwheelin with this thing as it is my highschool daily driver but if i get a 4inch does that mean i have to get longer driveshafts made?? what do you guys think the best choice for me would be thanks alot
    josh
    1986 k5,305,th-700r4,np-208,3.73 govlocker
  2. m1ndless
    m1ndless Banned
    Feb 18, 2007
    642
    Phoenix, AZ
    You should be able to fit 33"s with no lift, but you might need to trim, I would suggest a 4" so if you ever decided to go bigger.
    You can get a rough country lift for about 350 shipped, rear blocks though, which isnt bad, I am fine on my rear blocks, but I would suggest a shackle flip eventually.
  3. AFUFO
    AFUFO 1/2 ton status
    Apr 26, 2006
    329
    Chesapeake,Virginia
    2" Should be fine.. but as mindless said 4 if you ever plan on stepping up to 35s or if you go on rocky or rutted trails that require your suspension to be flexed out, go for 4"..OR trim a tiny bit on the fenders w/2 inch lift, but only if it does rub.
  4. runamok151
    runamok151 1 ton status Premium Member
    Oct 24, 2005
    12,560
    1,489
    the armpit of the east coast, 08046
    get the 4". i only put 2.5" skyjackers on when i went to 33s. they fit without any contact, but i always wished i had a little more clearance under the truck. when i went to 35s, i was tagging the front fenders all the time, until the tires knocked the rust off and did their own trimming. d shafts should be ok, but yu'll probably have to lengthen the brake lines and you'll need some steering correction
  5. Blue90
    Blue90 1/2 ton status
    Aug 27, 2004
    583
    4" All the way!
    I would go with a 4" lift it's the perfrect medium plenty of flex and not too big. There will be no trimming required although you will need to extend your drive line and front brake lines. Extending your drive line is not very spendy at all if you go to a mom and pop place. Mine cost me only 80$.
  6. AFUFO
    Apr 26, 2006
    329
    Chesapeake,Virginia
    extend driveline.. i guess my truck must be weird. Iv got a front driveshaft that goes in/out in the middle...greased.. and my rear slides in and out of tcase.. Pretty much means i dont have to extend anything if its just a tiny bit of difference.
  7. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    You shouldnt have problems just keeping it stock with a little trimming. Or go 2" if you have worn springs. I run 35's with a 4" and could go 37's. Some people trim to run 38's off of 4" lifts. Theres room inside the fenders for the tire unlike newer rigs. Alot of people go 4" because its just more lift. Lift as much as you need but as little as possible. The tires give the ground clearence. I plan to go 2" lift and do a little trimming for 35's when I replace my K20 with another K5. I would also suggest another lift company. Ive used Rough Country and they rode rough and were stiff. Also the back end was "stink-bugging." My next springs will be Tuff Country or BDS. Check out this spring rate table. Rough Country are one of the stiffest springs you can get. http://coloradok5.com/springratetable.shtml
    Also on my K5 the 4" lift caused vibrations and I went with a longer CV rear shaft front was fine.
  8. Blue90
    Aug 27, 2004
    583
    Your not alone there friend. I was referring to only the rear drive line. The rear yoke will slide in and out of the transfercase just fine for a short time (offroading). That amount of slip is not ment for daily use.
