2 wd steering box question
Discussion in 'OffRoad Design' started by bigwishlist, Feb 15, 2003.
  1. bigwishlist
    bigwishlist Registered Member
    Apr 14, 2002
    47
    Sheboygan Falls
    Will a steering box out of a 80-88 pickup bolt right in to a 94 silverado? I need a 2wd box for x over steering, right? and 89-96 2wd pickups are scarce at the junk yard, but old ones are everywhere.
  2. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    94 is IFS? the box on my 88 worked fine for D60 swap.Just need to find correct pitman arm from Ford truck or van.Using stock arm now,will change with new crossover link. /forums/images/graemlins/thumb.gif
  3. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    I don't know but the late model 1500 I saw in the JY had the PS box mounted on the inside of the frame not the outside like earlier ones were. /forums/images/graemlins/confused.gif
  4. ZonkRat
    Jan 16, 2003
    1,003
    94 Silvarado should be IFS and the box is on the inside of frame.The CKs turn side to side ,not front to back like pre IFS.The frame is stronger on IFS trucks,don't crack like oldr ones /forums/images/graemlins/thumb.gif
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    IFS trucks don't need a different box for crossover, just a different pitman arm.
