2 wd truck rims
Discussion in 'The Garage' started by cjjones, Jul 27, 2006.
  1. cjjones
    cjjones 1/2 ton status
    Feb 20, 2006
    111
    To the north
    Is a 2wd 6 bolt rim from 65-68 chevy trucks the same as a 78 6 bolt 4wd rim.
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    yes the lug pattern is the same, but i don't think the center hole is big enough to go over the frt hubs of a 4x4
  3. cjjones
    Feb 20, 2006
    111
    To the north
    That is what I had heard as well, wanted to make sure with others before I bought them. Thanks
  4. diesel4me
    Jul 24, 2003
    17,537
    922
    Massachussetts
    Diitto--
    Yep--the lug pattern is the same,but the centers might be too small to fit over 4wd hubs--also,drum brake wheels will rub the calipers if you use them on disc brake front ends--I ran some OEM 16.5" drum brake style 4x4 6 luggers with 1/4" wheel spacers on my 72 K5 with no troubles...but there IS less threads holding the lugs on when you use wheel spacers..
    I saw a K5 in the junkyard the other day,that had 14" 6 lug nissan rims on it,with the centers chopped out!--had 195/60/14's on it!--looked like skate wheels!...guess thats one easy way around those crappy 2.56 gears!..:eek1:
    :crazy:
