2 wheel drive/ 4 wheel drive box ?s
Discussion in 'The Garage' started by backyardbuilt, Feb 17, 2003.
  1. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    I thought I saw on here that the pitman arm shafts (not the arm but the shaft the arm mounts on) interchange from the 2 wheel box to the 4 wheel box but could not find it in my searching. Is this correct, if so it would be much easier than swapping the whole box since mine is good. Thanks for any help.
  2. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    I've seen aftermarket arm for 4WD box,but,don't know of stock arms that will swap.If can find where saw it will post. /forums/images/graemlins/thumb.gif
  3. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    If someone doesn't give a for sure answer try sending "Depdog" a pm... I seem to remember him saying something about doing that exact thing.
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    yes, the shaft is interchangeable.
    might as well replace the seals at the same time.
    grant
  5. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Thanks, I'm gonna change the whole box eventually I am tapping the 2 wheel drive box for hydro and doing the seals on it so while I'm doing that and getting the hydro parts I still wanted to be able to drive.
