2 wheel drive cab on 4x4 frame will it work?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by crazykev4x4, Mar 23, 2004.
  1. crazykev4x4
    crazykev4x4 1/2 ton status
    Jun 30, 2003
    430
    Watertown,Wisconsin
    2 wheel drive cab on 4x4 frame will it work? or will i need a body lift to clear the t case a. i think a 4x4 cab center hump is diff front to back
    Kevin
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ive heard the same. i have 2 2wd cabs and 2 4wd cabs and the floors are different but don't know if it will clear with out a body lift
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I have done it /forums/images/graemlins/grin.gif
    Looky here
  4. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    There is alot of good info in this post also and I posted a bunch of good links /forums/images/graemlins/thumb.gif
    Here ya go
    In the links I posted in those posts is everything you could ever want to know about cab swaps /forums/images/graemlins/waytogo.gif
    Chris
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    My truggy started out with a 2WD cab on a K30 frame due to a roll over that killed the original CUCV cab. Worked fine with a Th400 and 205, just had to cut a hole for the shifter and the hump was non removable.
  6. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    2wd cab will require a 4wd hump. Other than that is should go right in.
