2 wheel drive - lift or lower?
Discussion in 'The Garage' started by divorced, Nov 7, 2004.
  1. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I have an 89 chevy 2 wheel drive shortbed that I will begin working on soon. It has a 350 tbi, 700R4, and 3.42's w/ G80. It currently has a 2" body lift and 31/10.50x15 tires. Originally I had planned to lower it, but then I found this deal (Deal 1). What would be cooler, lowering it or raising it and running 33's? (If the 700R4 doesn't work with the 33's, I have a th350 that I could swap in.) Has anyone ever used a 2 wd lift kit? How well did or didn't it work?
  2. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    I'ld say stock hieght with 60's series tires all around.. Sweet.
  3. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    There is no reason what so ever that it would not work with the 700R4. As a matter of fact the trucks computer would prefer to keep it that way /forums/images/graemlins/deal.gif Whats gonna be the problem is the 3.42 gears. I would step up to a 3.73 or 4.10. Another thing would be to get some heavyduty balljoints if there is such a thing for 88-98 1/2 tons.
    If I did anything to My 96 C-1500 it would be to put in a prerunner kit and a rear locker.
  4. divorced
    Jul 20, 2004
    5,115
    This would be cool, but my daily driver is a 95 with 275/60x15's.
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I think 2wd trucks look cool with the rear at stock hieght, and the front lower 2".
  6. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    Put it in the weeds. Air bags are nice to set it on the ground when you park it but you have to hit the same PSI everytime to get it to align while driving. But if you don't c-notch the frame you didt go far enough /forums/images/graemlins/thumb.gif.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Since it's a shortbed...go 4/6 and lower that thing.
    If it was a longbed I'd say lift the front to level it.
  8. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
  9. cochino12
    cochino12 1/2 ton status
    Dec 23, 2003
    563
    Parker, Co
    Put it in the weeds
  10. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I would say lower it a little... but dont do like HUGE wheels or anything like that. but get a nice set Im really not a fan on lifted 2wd trucks because there prettymuch useless unless your going to to do like pre running or somthing like that. But if you WANT to lift it Just stick a sfa in it and run 35's /forums/images/graemlins/thumb.gif
  11. divorced
    Jul 20, 2004
    5,115
    Thanks for everyones ideas. I'm still kind of undecided. The truck will be a DD and occasionally see a mud road or two (if lifted). It would be cheapest to just leave it alone /forums/images/graemlins/thinking.gif, but what fun is that?
  12. divorced
    Jul 20, 2004
    5,115
    Is this your truck? It looks exactly how I have mine pictured in my head. It's clean and nice looking without a bunch of gaudy crap on it.
  13. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    Put it in the weeds
  14. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I'd leave it stock height and hang some 31-10.50 or 33-10.50 A/T's on it. Use a rubber mallet to move whatever sheetmetal out of the way of the tires, trimming only when absolutely necessary. Then I'd pull out the coils and work out what needs to happen to get more travel out of the front. You can get more travel from stock parts, don't need some long arm kit. Look into the 3/4t suspension parts (BJ's etc.), they may be adaptable and offer more travel than the 1/2t parts. This is true of the next earlier gen trucks. Cycle the suspension and get to to move easily. Hang some Z71 rear springs under the rear. Use the Figure 8 shaped bumpstops from a first gen Nissan Pathfinder. Would NOT put Rauncho's on it. Try some Bils 5100's or 5150's. They're nice for a DD b/c they have rubber eyelet bushes instead of spherical bearings (not noisey).
  15. lifethroughdeath
    lifethroughdeath 1/2 ton status
    Jan 26, 2003
    300
    New Bedford, MA
  16. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    asking what would be cooler is a personal question.
    If it was my truck I'd lower it, if you want a 4x4 sell it and buy a 4x4. Lifting 2wds is gay imo.
  17. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    lower it bro, then you have a big and a small one. /forums/images/graemlins/grin.gif
  18. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    I'd cast my vote for Lower /forums/images/graemlins/thumb.gif
  19. balzackks84
    Aug 22, 2002
    1,344
    portland, oregon
    Not mine just did a little google search to give a visual image of how good it could look if lowered /forums/images/graemlins/waytogo.gif
  20. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    TIM WTF HAS HAPPENED TO YOU?!?!?! /forums/images/graemlins/screwy.gif
    i agree though, 4/6 and maybe a set of 17s.
